muncie speedo bullet and adapter 1970 Z28
Discussion in 'Transmission & Driveline Topics' started by Jeffmort, Mar 22, 2017.
  1. Twisted_Metal
    25,760
    445
    It depends upon the rear gear ratio.
    Some gear ratio/transmission combinations required the adapter because the speedometer gear combination for accurate speedometer/odometer readings didn't exist.
    If your adapter has a 1.0 on it... it's not needed. (See pic above with .824)
  2. COPO
    16,337
    264
    I've always seen them on. My 71 Z28 M22 w/3.73 gears also had it.
  3. jbloake
    jbloake Veteran Member
    257
    32
    May 1, 2002
    NS Canada
    What does the P7 stamped on the end of the adaptor stand for ?
  4. 70lt1z28
    1,970
    250
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Anyone know the ratio it is supposed to have for a 3.73 rear gear? Is it the .8241?
  5. COPO
    16,337
    264
    P5 is in my 70 Z28 that came with a M20 - 1970 May (my car is a May car)
    P7 is what I had in my 71 Z28 with a M22 - 1970 Jul
    The P5 and P7 for example are date codes.
  6. jbloake
    257
    32
    May 1, 2002
    NS Canada
    Th
    Thank You !
  7. 70lt1z28
    1,970
    250
    Oct 3, 1999
    Mark,
    Good info. Thanks
    Was there a rear gear difference between the 70 and 71?
    My guess is the ratio inside is determined by the rear gear and tire size, not whether it was an m20,21,or 22.
  8. COPO
    16,337
    264
    Both my 70 (M20) and 71 (M22) Z28's has/had 3.73 gears and F60-15 tires on stock Z28 rims. The diff from 70 to 71 was a 12 bolt to a 10 bolt rear.
  9. jbloake
    257
    32
    May 1, 2002
    NS Canada
    This is from 73 and shows 373 and F60 15 and .8242
  10. 70lt1z28
    1,970
    250
    Oct 3, 1999
    Great. Thanks!. Now one more thing to find.
