muncie speedo bullet and adapter 1970 Z28
Discussion in 'Transmission & Driveline Topics' started by Jeffmort, Mar 22, 2017.
  1. Jeffmort
    Jeffmort Veteran Member Gold Member
    436
    10
    Jan 7, 2004
    Encinitas, CA USA
    Question:
    My "new to me" 1970 Z28 had an adapter fitted onto the speedometer gear bullet - I understand this is likely original to this car.
    My question is: why cant I simply thread my speedometer cable directly to the "bullet" and not use the adapter part? The threads for on the bullet seem to match the threads on the speedo gear.
    If I must use the adapter I will - I am mostly curious why the adapter is needed.
    See picture:
  2. JodysTrans
    JodysTrans Veteran Member
    281
    Feb 9, 2006
    Reading, PA
    Since your '70 Z has a 764 or the 584 tail extension, only the 8 tooth speedo drive gear was available back in the day for the Chevrolet's. The ratio adapter was used to properly calibrate your speedometer/odometer. You can eliminate the adapter, but your speedometer will be off.
    Today we have 7, 8, and 9 tooth speedo drive gears to eliminate these ratio adapters.
  3. Twisted_Metal
    26,129
    553
    The adapter is also a ratio modifier to get the speedometer to read accurately.
    If you look closely... There's probably a number on it specifying the ratio of the adapter.
  4. zachary8
    zachary8 Veteran Member
    221
    Jan 22, 2012
    Chicago, Illinois
    The speedo reading on my 70 Z is off. (Not the biggest problem in the world but it annoys me) I did a quick search on ebay and did not find any listings for an item like this. Could somebody please tell where they are available for sale. Thanks, Lou
  5. Twisted_Metal
    26,129
    553
    Zach... How far is it off? (@ 60 MPH)
  6. budro6968
    budro6968 Veteran Member
    2,612
    358
    Apr 2, 2016
    Jax Florida
    My 78 Z had that too. It had a two piece speedo cable. It never worked because the cable dropped down on the ground somehow and about ground it in half before I owned the car. I never fixed it. Drove with no speedo for 11 Yrs. My 81 Z with T-10 has the speedo hole on the pass side. The cable does not reach at this point. I think that it needs that same set up to work. I can't remember if the 78 was on the same side.
  7. zachary8
    221
    Jan 22, 2012
    Chicago, Illinois
    I have estimated that it's about 25% off. (slow)
  8. 70lt1z28
    2,475
    365
    Oct 3, 1999
    Beavercreek, Ohio, USA
    My 70z with 3.73's did not have one of these, but I seem to see them more on the 4.10 equipped cars.
  9. COPO
    16,705
    348
    70 Z28 speedo color s/b
  10. 70lt1z28
    2,475
    365
    Oct 3, 1999
    So are z28's supposed to have one or not?
