Mothers Powerball for headlights
Discussion in 'Detailing Topic' started by camarochevy1970, Feb 26, 2011.
  1. camarochevy1970
    camarochevy1970 Veteran Member
    7,608
    15
    Jan 23, 2003
    Pittsburgh, PA
    not sure I would say the headlight kit is hi dollar, I believe you can find it online for about $20
  2. 1971SS
    1971SS Veteran Member
    732
    Feb 5, 2011
    eastern NC
    I've used Brasso before..worked OK...
  3. muscl car
    but any plastic polish or polishing compound will work just the same or even better than using a so called 'headlight restoration kit'
  4. Twisted_Metal
    25,610
    383
    I use Meguiars Plast-X on tail lights, headlights and cluster lenses.
    If the plastic is scratched, I use a 1500 grit wet sanding block first.
  5. Blitzwing
    Blitzwing Member
    39
    Dec 11, 2007
    Ohio
    I usually wet sand them out starting with 1000-1500 depending on how bad they are then continue with 2000 and finish up with 3000 and then hit them with a buffer with any kind of non abrasive compound. There used to be a sealer for these things but wax seems to at least slow down the degradation.
  6. Silverblue75
    Silverblue75 Veteran Member
    259
    Jul 21, 2007
    Amarillo Texas
    i have used this also and it worked awesome!
  7. GoldenOne7710
    GoldenOne7710 Veteran Member Lifetime Gold Member
    4,279
    194
    Jun 23, 2004
    Athens, GA
    I've had decent results using "000" and "0000" steel wool, followed up with car polish.
    I've also been pleased using just this...
  8. jims73z
    jims73z Veteran Member
    1,220
    Jul 22, 2000
    laguna niguel,ca
    I color sand and clearcoat them. They don't yellow again.
  9. Buickfunnycar
    Buickfunnycar Veteran Member Lifetime Gold Member
    That's an interesting idea...never thought of that.
  10. camarochevy1970
    7,608
    15
    Jan 23, 2003
    Pittsburgh, PA
    wouldn't the clear start chipping from stones/bugs and such? Seems like a solid idea, just not sure how you would handle that if it occurs
