Mothers Powerball for headlights
Discussion in 'Detailing Topic' started by camarochevy1970, Feb 26, 2011.
  1. camarochevy1970
    camarochevy1970 Veteran Member
    7,649
    19
    Jan 23, 2003
    Pittsburgh, PA
    Had some of this so thought I would try it out on the worst car I could find today. Must say I was impressed. As you can see in the pictures, the headlights were rough to say the least. Following the directions, it only took me about 5 minutes to get both headlights cleaned up
    Before
    During
    After
  2. SupplySgt
    SupplySgt Veteran Member Lifetime Gold Member
    1,374
    Jun 20, 2009
    Finally back home!!!
  3. rwild1967
    rwild1967 Veteran Member
    251
    Aug 11, 2009
    Look behind you!
    I wonder if it will work on old foggy tail light as well?
  4. camarochevy1970
    7,649
    19
    Jan 23, 2003
    Pittsburgh, PA
    according to the package it will
  5. K5JMP
    I might have to give that a try on this set of tail lights I have in the shed..:innocent:
  6. muscl car
    can do the same with polishing compound or cream with a microfiber towel
  7. speedyrev
    speedyrev Veteran Member
    2,165
    Jul 30, 2003
    Jackson, MS
    The problem I have on mine is that they fog back up in a couple of weeks time. Is there anything that would make it last longer?
  8. Javelin3o4
    Javelin3o4 Veteran Member Lifetime Gold Member
    1,855
    10
    Apr 21, 2004
    Concord, CA
    I had I think a Maguires headlight cleaning kit and in the instructions it said after you were done to use wax on the headlights to help slow down the problem from comming back soon.
    I'm just going to buy a new headlamp for my 2k camaro because after someone hit it the drivers side has a brand new shiny one, so now i got mismatched headlamps as far as clarity.
  9. Dirt Reynolds
    Dirt Reynolds Veteran Member Lifetime Gold Member
    3,625
    Jan 17, 2003
    BC, Canada
    Wow, that's not bad. Quite a before and after difference.
  10. muscl car
    i've used this plastic polish from mothers and completely cleaned the soft top plastic windows of my old jeep from a hazy finish to a brand new appearance in a matter of a couple minutes on ea window , it also works very well on plastic headlight covers . you don't need the fancy hi dollar headlight polishing kits just this polish from mothers and a couple of micro fiber towels
