mother power ball any body use one?
Discussion in 'Detailing Topic' started by tims78camaro, Dec 15, 2009.
  1. speedfreak1000
    speedfreak1000 Veteran Member
    1,270
    Feb 20, 2009
    Springfield, kentucky
    sweet, im gonna try that this weekend.
  2. onebad71
    onebad71 Veteran Member
    412
    May 15, 2010
    georgia
    i made a powerball type polisher.. i took and old 1/2 inch wood auger bit cut the sharp tip off and left the top so it was a smooth rod. i picked up abou 10 foam balls from a crafts store. they cost about 75 cents a piece. then i cut a slit on the ball sprayed 3m glue on the shaft and stuck it into the ball and it will stick it self into it. it worked great for me and when the ball gets dirty i just stick it in a vise pull it off and hit the bit with a torch and melt the excess off. and repeat ill have to do a thread with pics on a how to. but be pacient it will be awhile before im able to..
  3. 71RS/SS396
    71RS/SS396 Veteran Member
    2,595
    20
    Aug 26, 2008
    Wake Forest NC
    The powerball works well on relatively flat areas but not in the corners. I use the cone they have for doing the corners. FYI you are not suppose to let the polish dry, you're suppose to wipe it away while it is still moist according to Mothers, then buff the residue with a soft cloth. I am going to try the corn starch, I haven't tried it but I am curious about the results.
  4. masparks
    masparks Veteran Member Lifetime Gold Member
    1,594
    Nov 7, 2006
    Gas, Kansas
    Joshua used one once.When I went to use it,it fell all apart.Made a big mess!
  5. delete-Z
    delete-Z Veteran Member
    173
    Nov 27, 2009
    Crawfordsville,Indiana
    I have used the ball on my welds & worked really well making the water spots come out & bringing out the shine in my wheels that I haven't seen in a long time. How does the corn starch work ? any side effects? damage?
  6. I use the big ball (Mother's) on my older paints with no ill effects. It's quick and easy, for my spring/fall waxes just for protection purposes. I still use carnuba by hand if I'm taking one to a show or something.
    I will say that the ball with a cleaner wax can be 'sorta' like buffing. I've actually brought back some dull paint with it, so you can assume it's generating more heat/pressure than you would with with your hand. This is a good thing on older paint, but my newer, nice paint still get only the hand treatment.
    You also have to watch your drill speed, it doesn't take much rpm's on paint that already looks ok. Sure is faster though.. :happy:
