Moroso mounts for LS swap?
Discussion in 'High Tech Retrofits' started by jester1, Feb 16, 2018.
  1. jester1
    jester1 Veteran Member
    2,367
    Jan 12, 2005
    Before someone gets their knickers in a bunch I searched and searched.
    Has anyone used moroso solid mounts 52610's and 62630 pads with an adapter plate such as the ICT billet?
    Ive pulled most my hair out trying to fit these.
    For those who have fit them did you bother to note the engine offset measurement?
  2. badazz81z28
    14,964
    191
    Las Vegas, NV
    Why do you want to use a solid mount with a LS engine?
  3. jester1
    2,367
    Jan 12, 2005
    I didn't want to fab motor & mid plates including drive line angles.
  4. badazz81z28
    14,964
    191
    Las Vegas, NV
    I just don’t want to see you crack the aluminum block
  5. jester1
    2,367
    Jan 12, 2005
    Ha, damn should have said its a 5.3 iron block. Its a temp build once it goes 8.49 ill pull the drive train and suspension and put it in another project and this will go back to street duty with a fuel injected BBC and 4 spd.
  6. jester1
    2,367
    Jan 12, 2005
    All done.
    Never mind.
  7. nobreaks254
    nobreaks254 Veteran Member
    455
    Jul 14, 2007
    aberdeen, SD
    so what mounts did you end up using?
