Mini flap discs
Discussion in 'Tips 'n' Tricks Topic' started by brooksman9, Sep 17, 2014.
  1. brooksman9
    brooksman9 Veteran Member
    5,982
    115
    Jun 10, 2007
    Olive Branch, MS
    Anyone know any tips or tricks to keeps these little discs from flying off the arbor and rolling to unknown parts of the garage when you lift and stop grinding with them?
  2. CorkyE
    9,703
    298
    Buy good ones and keep them within rated rpm. I only use them on a electric 4 1/2 angle grinder and don't have problems.
  3. CamaroDoc
    CamaroDoc Veteran Member
    1,886
    53
    Sep 13, 2003
    Skiatook, Okla. 74070
    Never had any problem with that. In fact, they are sometimes hard to get off the arbor...
  4. brooksman9
    5,982
    115
    Jun 10, 2007
    Olive Branch, MS
    Must be my cheap HF arbor
  5. 3SLO5
    3SLO5 Veteran Member Lifetime Gold Member
    3,639
    Jan 7, 2001
    Edison NJ USA
    indeed the hf arbor the center is not supposed to stick out its supposed to be flush with the rubber so the rubber pushes on the disk to keep pressure on it.
  6. brooksman9
    5,982
    115
    Jun 10, 2007
    Olive Branch, MS
    Yeah, I figured that might be the problem. Might try and see if I can find some little rubber spacer to use until I can get a new one. The threads weren't right on this one anyway.
  7. 79zBlue
    79zBlue Veteran Member
    251
    Apr 7, 2012
    long island ,NY
    I get mine from napa store.no issues
  8. brooksman9
    5,982
    115
    Jun 10, 2007
    Olive Branch, MS
    I bought a couple of arbors and some more flap discs from LeHigh Valley and there is definitely a difference. These should work much better. I'll let you know when I get around to using them.
  9. brooksman9
    5,982
    115
    Jun 10, 2007
    Olive Branch, MS
    No issues with the arbors from LeHigh Valley
  10. divemistress
    divemistress Veteran Member Lifetime Gold Member
    195
    May 21, 2014
    Oak Harbor, WA
    One I have been using are from that Orange Box store I used to work at in 2011 LOL
