mechanical fan to electrical fan conversion
Discussion in 'Tips 'n' Tricks Topic' started by xlargest, Jun 24, 2017.
  1. xlargest
    xlargest Veteran Member
    104
    Feb 23, 2016
    las vegas, nv
    Thanks guys, will look at it this weekend!
  2. BonzoHansen
    you use the ignition hot under the hood to trigger the relay not feed the fans so the amperage draw is near zero. You should pull the fan power off the battery or similar power point
  3. camaro71/holland
    1,029
    40
    Aug 27, 2003
    The Netherlands
    Use relays, preferably 1 for each fan.
  4. Coadster32
    1,476
    86
    Oct 2, 2013
    Milford,CT
    That's what I meant. Sorry...perhaps I didn't write it that way.
