massive oil leak front seal
Discussion in 'Troubleshooting & Diagnosis' started by Chuck71RS, Oct 8, 2017.
  1. Chuck71RS
    995
    24
    Nov 24, 2012
    Houston, Texas
    Replaced the 1-piece Fel-Pro PermaDry Plus (don't know the part #) with another Fel-Pro 1-piece PermaDry Plus OS 34509T. Did so while replacing the leaking rear main seal. Fel-Pro tech said this is part # I need. The box also ids as 350 1967-1971
    • The previous 1-piece had already been installed twice
    • The previous gasket did not leak, only the rms.
    • The oil pan has a very slight tad of wobble at one corner
    Started up the engine and less than one minute (with some engine rev) found this on the floor. I could see oil on the bottom of the front seal. No oil was coming from anywhere else. (By the time I took the photo the oil had spread out ).
    Checked the torque on the end bolts and as called for (18ft lbs)
    The bottom of the seal is loose. Came move it with my finger
  2. Bandit723
    Bandit723 Veteran Member
    2,257
    262
    Oct 1, 2016
    Waupaca WI
    What year engine do you have?
  3. Chuck71RS
    995
    24
    Nov 24, 2012
    Houston, Texas
  4. badazz81z28
    14,177
    110
    Las Vegas, NV
    Cardinal likes this.
  5. Chuck71RS
    995
    24
    Nov 24, 2012
    Houston, Texas
    WOW...!! and DI Fel-Pro tech
  6. PalmbchZ28
    PalmbchZ28 Veteran Member Gold Member
    578
    187
    Jan 29, 2017
    West Palm Beach Fl
    Front oil pan id seal
    chevytech.com/2c70o1.html
  7. Chuck71RS
    995
    24
    Nov 24, 2012
    Houston, Texas
    With more info from Fel-Pro tech, the root cause of the leak is the oil pan (1986 purchase from a Chevy dealership) being for a 1975 and later which used the thick seal 2 3/8". The 09T (with the thinner front seal 2 1/4") is the correct for 1971.
    The rear seal remained the same size
    Ordered the 10T rather than replace the oil pan
    Apology to Fel-Pro tech and a pox on the Chevy dealership
