Manual vs Th350 Transmission. Swapping?
Discussion in 'Transmission & Driveline Topics' started by LeadHead, Nov 3, 2012.
  1. LeadHead
    LeadHead Member
    47
    Oct 23, 2012
    Napa, CA
    So I have a Th350 in my camaro 1974, I have a 350 v8 thats kinda just stock right now.It has a floor shifter.
    I was thinking of either restoring this engine and upgrading it, or dropping a big block 454 in there.
    Either way. I want a Manual transmission. I was thinking to put a good manual from the time where it would ahve been made, which would be a 700r4 (correct me if im wrong haha) I believe.
    I'm not sure how that trans compairs to other transmissions (maybe a newer style/model?). Im not building it for performance just yet, so i would like if it was something that could support the high power later on.
    Someone told me that theres some ways to modify or buy a modified Th350 that can do a race start thats faster/better/whatever than a manual trans. Though i've always assumed manuals won over autos for performance due to lower weight and more control over the car.
  2. Z-WIZZ
    Z-WIZZ Veteran Member
    1,297
    Mar 18, 2004
    FLA
    700r4 is an auto trans...autos are preferred for drag racing
  3. LeadHead
    LeadHead Member
    47
    Oct 23, 2012
    Napa, CA
    oh, see thats embarrasing haha.......
    how hard is it to switch to a manual from an auto?
  4. Z-WIZZ
    1,297
    Mar 18, 2004
    FLA
    many on here have done it, trick is to get a donor car with all the parts
  5. Fbird
    2,432
    99
    Feb 12, 2011
    atlanta, ga
    depends on WHICH manual your switching to.
    Muncie = easy peezy
    T10 = not a BIG deal but a few more parts
    Saginaw = why bother
    Tremec 600 = little complicated, a few special parts.
    1 question. How much money do you expect to spend?
    NOW multiply that times 1.5
    NOW you should be close.
  6. Hey G
    Hey G Veteran Member
    521
    Mar 18, 2012
    SC
    350 auto vs manual trans
    If you want to have fun with your car, 4-speed is the way to go. I like the original Muncie 4-speed. Find one with fine spline input shaft and a 1 inch counter-shaft and you will have a very sturdy trans. Also, there are plenty of vendors still making parts for these trans. The car is very easy to swap to a four speed. Places like NPD sells a kit with most of the parts.
  7. LeadHead
    LeadHead Member
    47
    Oct 23, 2012
    Napa, CA
    Thanks for the responses haha!
    I think I might just do a Muncie 4-speed. Seems to be the cheapest and easiest of the solutions.
    Honestly i'm not sure what my budget for this is, but i do want to swap this transmission while i have the itnerior gutted so i dont ahve to do it later.
    just how easy would it be to swap my th350 for a muncie?? do i need different driveshafts or what?
    EDIT: I looked on NPD real quick and i didnt see a th350/400 to Muncie :(
  8. Mr.Bill
    Mr.Bill Veteran Member
    444
    Apr 28, 2012
    Sparks, Nevada
  9. Thunderkyss
    Thunderkyss Veteran Member
    222
    Sep 16, 2012
    Texas
    Nice.....
  10. Mr.Bill
    444
    Apr 28, 2012
    Sparks, Nevada
