Manual OD transmission options
Discussion in 'Transmission & Driveline Topics' started by Jeep43, Jan 8, 2019.
  1. Goodwrench1965
    Goodwrench1965 Veteran Member
    922
    41
    Apr 23, 2010
    Charlotte NC
    I have a 73 Z28. I installed a Tremec 3550 which I think has the same external dimensions and shifter locations as the TKO600. I lowered the engine and trans down about 1/2” or so from place where it sat with old 4 speed when I adapted the transmission crossmember by cutting it. The new shifter worked with only slight trimming of steel floor around hole. The shifter works in the factory center 4 speeed console.
    http://www.moderndriveline.com/Technical_Bits/tremec_tr-3550.htm
  2. biker
    biker Veteran Member
  3. CAMeeks
    CAMeeks Veteran Member
    684
    33
    Jan 5, 2014
    Deer Park, TX
  4. Jeep43
    Jeep43 Veteran Member
    1,107
    21
    Mar 30, 1999
    Connecticut
    Anybody have a pic of where the factory TKO shifter stub sits in regards to the OE 4 speed shifter hole?
  5. Jeep43
    1,107
    21
    Mar 30, 1999
    Connecticut
  6. czizza
    czizza Veteran Member
    907
    25
    Jan 8, 2004
    N. Massapequa, NY, USA
    Yes Jeep43, my install need some minor tweaks but mine was a craigslist buy. If you buy from SST you will have the shifter back about 3 inches which will put it right where it needs it.
  7. orkin
    orkin Veteran Member
    251
    Apr 27, 2011
    Georgia
    I have a T56 magnum with the tall solid body bushings from PTFB and it fits great.
  8. black_aerocoupe
    Jeep43,
    Since you did the mechanical T56 almost 20 years ago, what would you want to change this time?
    Shifter position?
    Mechanical speedo drive?
    Crossmember?
    Exhaust clearance?
    Differential ratio?
    Gear ratios?
    Clutch?
    Flywheel?
    Starter?
    I kept my front adapter plate that is adapted for mechanical (but the trans. got adapted to LS input / plate)
  9. redriderjf87
    redriderjf87 Veteran Member
    121
    11
    Jan 23, 2016
    Quad Cities, IL
    My TKO600 was from Hurst Driveline, I'm not sure how much the fitment / exterior of the trans would change but mine did fit with no real cutting in the floor. I used Hurst's Blackjack shifter which did allow me to offset to the left a little.
