manifold leak test
Discussion in 'Tips 'n' Tricks Topic' started by C-Man, Nov 25, 2001.
  1. C-Man
    C-Man Veteran Member
    2,544
    Oct 3, 2001
    Port Orchard WA.
    A friend suggested using a propane torch to test for intake manifold vacuum leaks. you don't light the torch you just use the gas, open the torch to let the gas run and run the tip around the edge of the intake and if there is a vacuum leak it will suck the gas in and change the engine idle.
  2. n2omichael
    n2omichael Veteran Member
    485
    Dec 13, 2001
    Toronto, Ontario, Canada
    WD40 does the same thing, good luck!
    Michael
  3. Daniel
    Daniel Veteran Member
    3,758
    Sep 6, 2000
    FL
    wd40 is IMO a lot safer.
  4. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    It works very well.
    70 SS 454 CI 650+HP All Aluminium Fuel Injected Small Block
