M22 Muncie
Discussion in 'Transmission & Driveline Topics' started by Slideways, Dec 1, 2017.
  1. Slideways
    Slideways New Member
    13
    Oct 7, 2017
    Springfield Missouri
    Was wondering what a freshly rebuilt M22 with a new clutch, Lakewood bellhousing and Hurst comp shifter would be worth? Whole driveline has 700 miles since rebuild. Considering changing the car over to a auto.
    Jeremy
  2. HawkX66
    HawkX66 Member
    84
    22
    Sep 20, 2017
    MI/MA
    Real M22 or a/m?
  3. Slideways
    13
    Oct 7, 2017
    Real M22, not sure what it was originally out of. My car was originally an automatic.
  4. 70lt1z28
    1,533
    170
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Clutch include?
  5. Slideways
    13
    Oct 7, 2017
    Yep, 11” HD
  6. COPO
    16,040
    201
    Check what the VIN is on the trans and post it.
  7. 70lt1z28
    1,533
    170
    Oct 3, 1999
    Is it a early-70 M22 or a 71-later?
    Other words, fine spline input/400 turbo size output or a coarse spline input/350 turbo sized output?
  8. Slideways
    13
    Oct 7, 2017
    The guy that rebuilt it said it had a turbo 400 tailshaft!? I’m not a transmission guy! Know just enough to be dangerous.
  9. 70lt1z28
    1,533
    170
    Oct 3, 1999
    For the whole setup I would say ~2k. You may have to wait awhile though. For a quick sale maybe 1200 to 1500.
    Unless you find the guy that is doing a numbers matching type of resto, most folks are looking for a TKO or T56 overdrive setup so they can drive on the highway. M22's are rare, but not necessarily desirable especially for the street these days. Even wide ratio M20's are a better street trans cause you can run a taller rear gear and still get off the line good. If it has the right numbers for an LS-6 Chevelle or something like that you'll get the big bucks.
  10. Slideways
    13
    Oct 7, 2017
    Excellent, thank you. Your right, the tranny is a little whinny in 1st and a little bit in second and the close ratio would be great to road race but I find it a little bit annoying! I don’t think the motor that’s in it would like any part of an overdrive. Thinking Turbo400 or something. Thanks again!
