LS7 install?
Discussion in 'High Tech Retrofits' started by Revin, Feb 4, 2018.
  1. badazz81z28
    14,279
    123
    Las Vegas, NV
    Yes the LS7 is happiest and safest as a N/A engine, it can and has been used with superchargers but it's not recommended for high boost. The LS3 would be a better choice for forced induction but also has its limitations since it doesn't have forged pistons. Honestly....A turbo car I would save the money and work on a 5.3LS and put the right parts in it for forced induction.
  2. frankz
    frankz Veteran Member
    2,062
    Aug 24, 2009
    Illinois
    Clean install.... which Petersen tank is that ?
  3. Zulu28
    Zulu28 Veteran Member
    191
    13
    Dec 19, 2013
    Vancouver, BC
    I'm thinking I'll keep the dry sump, sure solves the oil pan clearance issues, even though the factory dry sump isn't the best system it has to be better than the relatively shallow F Body pan.
  4. Lowend
    14,242
    207
    Mar 25, 1999
    San Jose, CA, USA
    Everyone I know who has an LS7 Corvette (~20 people) has needed to go through the heads. Some of them caught it early enough; a couple had the valve drop and ate the motor. This is over a variety of production years.
    GM has definitely tried to downplay this but there is an active class-action lawsuit over the LS7 heads covering thru 2013
    http://corvettec7fiasco.blogspot.com/2015/10/more-information-on-class-action.html
  5. badazz81z28
    14,279
    123
    Las Vegas, NV
    The F-body pan doesn't hold a ton of oil, but I believe the 5th gen LS3 pan is a higher capacity. I'm using the Peterson Drag tank which they custom modified for me. I had them add AN fittings and remove the heater bung. They told me it shy of 3 gallons.
  6. DB Z28
    DB Z28 Veteran Member
    504
    15
    Nov 30, 2003
    Fond Du Lac
  7. DB Z28
    504
    15
    Nov 30, 2003
    Fond Du Lac
  8. Randy 81
    Randy 81 Veteran Member
    881
    9
    Oct 28, 2009
    Loganville, Ga
    5th gen LS3 pan is 8 quarts with filter.
  9. Lowend
    14,242
    207
    Mar 25, 1999
    San Jose, CA, USA
  10. badazz81z28
    14,279
    123
    Las Vegas, NV
    There shouldn’t be any issue using an OEM F-body pan.
