LS7 install?
Discussion in 'High Tech Retrofits' started by Revin, Feb 4, 2018.
  1. Revin
    Revin Veteran Member
    439
    54
    Aug 31, 2016
    Round Rock , TEXAS
    Can I fit an LS7 into my 73?
    Issues?
    I could not find any threads about it.
    Thx
  2. DB Z28
    DB Z28 Veteran Member
    546
    36
    Nov 30, 2003
    Fond Du Lac
    No issues drops right in .Only issues is where you want your dry sump tank .
  3. Revin
    439
    54
    Aug 31, 2016
    Round Rock , TEXAS
    Can it be wet sump?
    Like a ls3 oil pan?
    Got a chance for a 5000 eng trans.
  4. badazz81z28
    15,473
    232
    Las Vegas, NV
    Yeah...space is limited and the parts are expensive. If I had to do it again....I would convert it to a wet sump.
    My car is a 1970
  5. Revin
    439
    54
    Aug 31, 2016
    Round Rock , TEXAS
    Hmmm
    Maybe I will stick with LS3, I wanted instead.
    Bet it is a hoot to drive though.
  6. badazz81z28
    15,473
    232
    Las Vegas, NV
    LS3 is a great engine....but its not an LS7. There’s just something about 427 cubes!
    You can’t compare the two cube for cube. The LS7 is 60+ ci bigger! That’s significant. Just saying lol..
  7. Lowend
    14,712
    350
    Mar 25, 1999
    San Jose, CA, USA
    As much charm as the LS7 has, I'd probably go LS3. The LS7 had some pretty serious cylinder head issues. Unless you get one that's already had the valve guides replaced, it's a problem waiting to happen.
  8. Zulu28
    Zulu28 Veteran Member
    266
    17
    Dec 19, 2013
    Vancouver, BC
    Yes, depending on production date, my understanding is as of February 2011 GM had isolated the valve guide issue.
  9. badazz81z28
    15,473
    232
    Las Vegas, NV
    Not really...the LS9 also had some bad heads but it’s not a epidemic like the internet makes you believe. Not every corvette owner hangs out on the corvette forum. It cost me nothing to have the heads checked and there was nothing wrong with them at 38k miles. If the heads were defective, they failed early in life.
  10. Revin
    439
    54
    Aug 31, 2016
    Round Rock , TEXAS
    Yes 427 has a very nice ring to it when asked your engine size...
    Seems just like old days where BBC parts were more $ than SBC.
    What is the 396 version in LS series?
    LS3 may be more forgiving if a turbo or two were needing space.
