LS swap, upper/lower radiator hoses. What did you do??
Discussion in 'High Tech Retrofits' started by QUAKE_WARS, Jun 28, 2017.
  1. Custom or stock, what did you use?. Looking for ideas, thinking of using 90 degree elbows with copper tubing. I would like to see some options before I spend more $$$$$$$$$''......
  2. Goat
    1,772
    19
    Jun 7, 2001
    moncure, NC
    Are you talking about using the original style radiator with the outlets in the wrong place? I decided it would be easier/cleaner looking to just get a radiator for an LS engine. Not the cheapest option though...
  3. badazz81z28
    14,555
    149
    Las Vegas, NV
    QUAKE_WARS likes this.
  4. CasperCasper
    CasperCasper Veteran Member
    989
    106
    Aug 11, 2015
    I used polished stainless tubing which I welded together and re polished. The tubing is connected to rad and pump with silicone couplers. Dont use ugly metal flex or rubber hose please.
  5. 76_TypeLT
    6,392
    136
    Jul 26, 2008
    Houston, TX
    Where are the inlet and outlet located on your radiator? I ask because I don't want to advise what I used in the event we have different radiators.
  6. I ask in another post for you to call me, not sure if you seen it. I need info from you. Thanks
  7. 76_TypeLT
    6,392
    136
    Jul 26, 2008
    Houston, TX
    I'd be happy to call you if I had your phone #. :)
  8. Tpichevy
    Tpichevy Veteran Member
    422
    13
    Jun 21, 2016
    Boise id
    Subbed for info...going to have the same issue with my LS1 Corvette swap
  9. 1slow70LS
    1slow70LS New Member
    Oct 18, 2017
    I used a napa nbh8333 for the lower hose from my factory style radiator to my 5.3. I dont have part number for the upper sorry.
