Lost need help again
Discussion in 'Transmission & Driveline Topics' started by Chevyryder, Dec 27, 2017.
  1. Chevyryder
    Chevyryder New Member
    15
    Sep 27, 2017
    Need help my 93 chevy caprice 700r4 want shift out of first it was doing it with my old transmission ... I have new transmission new speed sensor.but one thing after I put the new transmission in when you put it in drive and start moving the speedometer goes to a hundred..Help
  2. Gary S
    21,437
    412
    If this car has a TV cable, make sure the it is properly adjusted. If it isn't adjusted correctly, the tranny will shift out of first very late or not at all.
    If it is all electronic, it becomes a different game.
  3. camaro71/holland
    1,049
    43
    Aug 27, 2003
    The Netherlands
    All 700r4's are non electronic and have a TV cable.
    If cable adjustment won't help, the problem can be in the 2-4 servo under the round cover on the side of the trans.
  4. budro6968
    budro6968 Veteran Member
    2,609
    358
    Apr 2, 2016
    Jax Florida
    Does the Speedo in the dash have a stepper motor or is it cable driven? My GMC has stepper motors that went bad. Has to be desoldered and new one soldered in.
  5. badazz81z28
    14,951
    189
    Las Vegas, NV
    The speedo is cable driven
  6. CorkyE
    9,709
    298
    Not all 700-R4 speedometers are cable driven, later models have the electronic output. I had to convert mine back to mechanical. If yours is electrical, check the connections and if they're good, I'd suspect the stepper motor as Budro mentioned.
