Looking for some advice for a change
Discussion in 'High Performance Modifications' started by jvle95, Feb 1, 2018.
  1. jvle95
    jvle95 Veteran Member
    157
    May 14, 2007
    SF Bay Area, CA
    Lowend, the Crower you recommended to me is for my set up. The Jones and Straub cams are ones that 77 cruiser was or is using for his set up which I believe is a bigger displacement more aggressive set up. Either way I see what your saying.
  2. 8pack
    2,390
    72
    Aug 29, 2007
    Pittsburgh, PA
    FWIW, I know this doesn’t apply to your engine but maybe it isn’t informative, this is my hydraulic roller cam sheet for my 383 with 195/65 AFR aluminum heads. Running 1.6 rollers, airgap intake, Holley 670 Avenger. Made 450hp on the DYNO Andrew 460ft/lbs. Ignore the reference to the rocker ratio, that’s not where we wound up.
