Leaf spring bolts at torque box.
Discussion in '1978 - 1981 Specific' started by cam2z28, Dec 13, 2017.
  1. cam2z28
    cam2z28 New Member
    9
    Nov 12, 2013
    Shoemakersville, PA
    Hey, guys.
    I'm trying to remove my rear leaf springs and rear axle on a 78 Z28, but the 3 bolts at the torque box area are just spinning. Do I need to cut into the floor to get access to the bolt nuts? Is there a better way to solve this problem?
    Thanks
  2. NOT A TA
    NOT A TA Veteran Member
    191
    48
    Feb 12, 2009
    Delray Beach Florida
    Grind/cut the heads off the bolts. Once you remove the spring pockets the remaining U nuts and cut off bolts are easy to remove.
    This is a 1st gen but gives you the idea.
  3. NOT A TA
    191
    48
    Feb 12, 2009
    A little info on the replacement hardware. The U nuts are special ones. I don't like the China replacement ones sold under the OER labeling by most restoration houses. They get cross threaded and strip more easily than the CIP ones originally used by GM.
  4. cam2z28
    cam2z28 New Member
    9
    Nov 12, 2013
    Shoemakersville, PA
    OK, I understand, Thank you!
  5. cam2z28
    cam2z28 New Member
    9
    Nov 12, 2013
    Shoemakersville, PA
    Ok, thanks. Where can I get the CIP nuts from?
  6. NOT A TA
    191
    48
    Feb 12, 2009
    I do business regularly with Dave at PTFB http://pro-touringf-body.com/ and get them from him in bulk because I use them often. I think you may still be able to get them from a local NAPA store.
