killswitch
Discussion in 'Tips 'n' Tricks Topic' started by 7383camaro, May 13, 2005.
  1. wookie
    wookie Veteran Member Lifetime Gold Member
    3,037
    Jul 12, 2006
    Daytona Florida
    I would love to know how to wire this defrost type start switch!!
    PM me with instructions PLEASE!!!
  2. angel71rs
    angel71rs Veteran Member
    1,343
    Jul 28, 2002
    El Paso, TX
    Front AND rear? Jeebus. I like to leave my front wheels cranked all the way over when I park my 98 in my gf's driveway overnight (one car garage). Makes it impossible to pick up from the rear wheels and drive away. Wonder if cranking the wheels would prevent a 4 wheel unit from lifting it?
    Well, at least her driveway is right under her bedroom window and she keeps a revolver in her bedstand.
  3. muscl car
    that won't help either they will just use gojacks under the front wheels and your car is easily moved off the driveway .
  4. spoonLT1355
    spoonLT1355 Veteran Member Lifetime Gold Member
    5,511
    Mar 1, 2003
    Rockledge Pa
    I have had cars that I put an electric door lock switch in the door and wire it as a kill switch. You could do the same with a defroster switch in the dash or a window switch in the console.
    Use the factory switch in the correct place.
    A thief will (usually) not try all the factory looking switches.
    Another trick is to wire a second headlight dimmer as a kill switch and leave it under the carpet near the orig. one.
  5. ZS10
    12,165
    Jan 18, 2003
    BC, Canada
    Leave the line-lock on, tail panel cutout switch off, and fuel pump off.
  6. Lencross
    Lencross Veteran Member
    Previously posted was : wire a 20 a switch between yr dist and battery...
  7. phillyparot
    phillyparot Member
    92
    Nov 30, 2004
    Philadelphia, MS, USA
    My MSD has an extra wire that can (and will) be used to kill the ignition.
  8. ChillPhatCat
    ChillPhatCat Veteran Member
    359
    Jun 9, 2005
    Ballston Spa, NY
    I've got a switch in my ash tray I was planning to wire into the middle of my tach wire... the car ought to run for a few seconds and then die and basically act like it's a busted POS.
  9. IDLZRUF
    IDLZRUF Veteran Member Lifetime Gold Member
    Jacobs electronins makes or made a anti theft device where if the car gets stolen or car jacked it dies a short way down the road
  10. doechsle
    doechsle Veteran Member Lifetime Gold Member
    mine is just ugly
