Kerosene to flush engine???
Discussion in 'Camaro Questions' started by White81Z28, Mar 22, 2008.
  1. White81Z28
    White81Z28 Veteran Member
    Sorry but what is atf?
    BAAV...no, I was at Advance getting the Seafoam to clean out the carbon in the intake. The guy knew it was for a 81 Z and asked me what my oil looked like, I told him black. Thats when he said to do the kerosene trick.
  2. TheFly
    TheFly Guest
    automatic trans fluid........ What you put in your tranny.
  3. twozs
    twozs Veteran Member
    8,573
    106
    Aug 5, 1999
    hopewell jct ny
    replace main and connecting rod bearings as needed (immediately)
  4. SledZ28
    SledZ28 New Member Lifetime Gold Member
    28
    Nov 29, 2007
    Concord, CA
    I had a hole bunch to say here, but FLY beat me to all of it. If you want good advise about what to do, FLY's got it dead on!!!
    SledZ28
  5. al8apex
    al8apex Veteran Member
    3,916
    Mar 11, 2005
    scottsdale, az
    Automatic Transmission Fluid ...
    it has fantastic cleansing qualities while maintaining viscosity, works GREAT
    you can even use it straight ... but best to mix in regular oil
  6. al8apex
    3,916
    Mar 11, 2005
    scottsdale, az
    ATF works GREAT in combination with regular oil to clean the inside of the engine while maintaining proper viscosity, something kerosene will not do ...
    you don't do it for thousands of miles, just until you see the oil change colors
    takes a lot of flushing, but done properly, it WILL work without damaging bearings or rings/bores
  7. al8apex
    3,916
    Mar 11, 2005
    scottsdale, az
    how would someone know that? :eek:
    Marvel Mystery Oil does work well also, the ATF is just ANOTHER method that works well too :happy:
  8. TheFly
    TheFly Guest
    You don't really work on cars if you haven't tasted about every fluid in it, one way or another.
  9. brick_haus
    brick_haus Veteran Member
    525
    Oct 22, 2006
    Somis, Ca.
    :eek: I dont think its how you know the taste of the oil that we're wondering ...
  10. 71 Camaro
    71 Camaro Veteran Member
    1,682
    Jan 10, 2007
    Cedartucky
    I've done most all the things mentioned with good results. As always a little common sense goes a long way here.
    fwiw, I am not familiar with the taste of any fluids other than gas and antifreeze which I've had to siphon a time or two.
