Just finished Lt1 swap..
Discussion in 'High Tech Retrofits' started by Baseballstud, Feb 2, 2006.
  1. Baseballstud
    Baseballstud Member
    99
    Feb 12, 2004
    Jax, fl
    If anybody has any questions they can feel free to e-mail me at baseballstud6585@yahoo.com ... I used the motor and tranny of a caprice and used that wiring harness so i went through the whole process.. i didn't buy the kit, but would recommend it..
  2. badazz81z28
    14,277
    123
    Las Vegas, NV
    Do you have any pictures??? The caprice has Iron heads didnt they? Did you swap them out for the F-body aluminum heads?
  3. tgw323
    tgw323 Veteran Member
    468
    Jun 25, 2000
    Roanoke, Ind.
    What kit are you referring to? What fuel pump did you use? Who did the wiring harness mods? As far as the iron heads,they flow better than the alum. ones. About 40 lbs. diff. Not that big of a deal.
  4. RaycerX81
    RaycerX81 Veteran Member
    552
    Dec 11, 2004
    Hayward, Ca.
    The LT1 for the Impala/Caprice/Roadmaster, put out 260HP at the fly wheel and 335 lb.-ft. where the camaro put out 275hp and 325 lb.-ft and the corvette put out 300hp and 330 lb.-ft. Also the Impala/Caprice/Roadmaster ran true duel exauhst pipes but also had 4 O2 sensors, where the camaro ran the single setup, not sure about the vette. Plus side is with that setup you can legally run the duel exauhst on your car even in California.
  5. badazz81z28
    14,277
    123
    Las Vegas, NV
    are our Camaros still not smog exempt????
  6. Todd80Z28
    10,896
    25
    Jun 11, 2002
    Northern VA
    I didn't think the 4 O2 sensors showed up until '96, with OBDII?
    I shoulda picked up that '95 LT1 engine (complete) for $1200 when I had the chance. It only had 28k miles on it. I was (still am) thinking LS1, though, so I hesitated.
  7. BC's71'
    BC's71' Veteran Member
    1,125
    May 16, 2000
    North Chicago Suburbs
    Bingo, you are correct.
    Be weary of misinformation.
  8. BC's71'
    1,125
    May 16, 2000
    Hopefully will get a chance to pick your brain when I dig into mine later this year (I hope I finally get into it!). I also plan to use the stock Caprice wiring harness.... although I'm going with TH350 for tranny.
  9. 3_z28camaro
    3_z28camaro Veteran Member Lifetime Gold Member
    4,447
    Dec 17, 2004
    Acton, CA
    I am thinking of doing a LT1 swap and I was curious if I can hook the LT1 up to a 700R4 instead of a 4l60E? Also can I use a stock big block radiator for our cars rather than the radiator that accompanies the LT1?
  10. tgw323
    468
    Jun 25, 2000
    Roanoke, Ind.
    From what I've read,you can use a regular radiator. You can go with a 700R4,the big trick will be getting the cussed TV cable adjusted so it works right.
