Intermediate steering shaft
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Layne02, Jan 14, 2018.
  1. Rayden2009
    Rayden2009 Member Gold Member
    46
    May 12, 2016
    Calgary AB
    Looks like the bottom one. 2 d’s back to back. They can be various sizes.
  2. ULTM8Z
    ULTM8Z Veteran Member
    8,529
    128
    May 19, 2000
    Los Angeles
    Ok thanks. Yeah mine looks like the top one actually. Diameter measures 1".
    Guess I'll call borgeson tomorrw and see what I need to get.
    I'l probably just do the lower joint to keep the cost down since I also want to get the global west rear leafs soon as well.
  3. Rayden2009
    46
    May 12, 2016
    Calgary AB
    The stock shaft is made to bolt on to the rag joint. Up at the column end, it has two pivot points that stick out to attach to the stock bell joint. This means new borgeson U joints will not be able to attach to your existing shaft. I think is all or nothing if you go the boreson route. The individual peices are not compatable with stock stuff.
  4. ULTM8Z
    8,529
    128
    May 19, 2000
    Los Angeles
    Yep, you're correct. Just called Borgeson... they gave me the p/n's of what I need...
    014352 upper column U-joint
    450024 intermediate shaft
    034940 vibration dampener
  5. ULTM8Z
    8,529
    128
    May 19, 2000
    Los Angeles
    Well I gone and done the deed... parts are on order from Summit.
  6. Rayden2009
    46
    May 12, 2016
    Calgary AB
    Right on. Be sure to post your progress. Your not going to regret it!
  7. woody80z28
    5,460
    16
    Sep 8, 2004
    walton, ny usa
    I got a Jeep shaft forever ago from a guy on TG.O, but haven't driven with it yet. They do seem a little wimpy.
    Too bad I didn't clearance that part of the subframe while I recently had it cut up in bare metal. haha
  8. ULTM8Z
    8,529
    128
    May 19, 2000
    Los Angeles
    Parts arrived today...
    damn, these things look seriously heavy duty. Looking forward to getting them on the car!
    So far you guys on this site have been 100% correct on the benefits of the Y-braces and upper control arms... so I expect the same here! :)
  9. Rayden2009
    46
    May 12, 2016
    Calgary AB
    Wow gotta love the US. Takes at least a week to get to Canada plus I get bent over the barrel on shipping and duty
  10. largestar
    largestar Member
    50
    9
    Nov 21, 2017
    If anyone is on the fence about this, do it. It is a solid upgrade
