Intermediate steering shaft
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Layne02, Jan 14, 2018.
  1. Rayden2009
    Rayden2009 Member Gold Member
    59
    May 12, 2016
    Calgary AB
    I'll take some pictures in the next day or so and post them here with approx. measurements. I'd say there is more like 1/8"-1/16" clearance between the U- joint and the crossmember. As long as it doesn't rub, I don't care. If it does, out comes the Dremell to shave 1/100th of an inch away from the rub spot.
  2. NeoNeuro
    NeoNeuro Veteran Member
    186
    Aug 4, 2014
    Panama City, FL
    Not sure if these will help, but I scrounged these up in the Super Chevy archives.
    sucp_0309_02_z+borgeson_steering_shaft+length.jpg sucp_0309_03_z+borgeson_steering_shaft+distance.jpg sucp_0309_05_z+borgeson_steering_shaft+portable_saw.jpg sucp_0309_06_z+borgeson_steering_shaft+dimple_drill.jpg sucp_0309_07_z+borgeson_steering_shaft+dimples.jpg sucp_0309_08_z+borgeson_steering_shaft+interference.jpg sucp_0309_09_z+borgeson_steering_shaft+grinding_small_parts.jpg sucp_0309_10_z+borgeson_steering_shaft+jam_nut.jpg sucp_0309_11_z+borgeson_steering_shaft+u_joints.jpg sucp_0309_12_z+borgeson_steering_shaft+shaft_joint.jpg
  3. Rayden2009
    59
    May 12, 2016
    Calgary AB
    Yup, thats exactly what I went threw, except he has way better tools. You can see his clearance between the lower isolator joint and the crossmember is tight; about the same as mine. I went out and took some photos today, even though its 5F outside.
    Rw6qbSmfQQibCooquEHL5g.jpg R+LtntjsSMi5v1rcIi4AIA.jpg clanlYo8QUaXqy5BKH9acQ.jpg A4xfpxChT9GfNvAb0VPFzw.jpg ysU5pac+R3qdxoZ2+QcH5Q.jpg
    From the end of the 670 box to the beginning of the crossmember is ~3.5"-3.75", so that will give you a rough idea if the 800 box brings the end closer to the crossmember. I doubt it, but notice the guy in the post above appears to have a 670 as well....
  4. ULTM8Z
    ULTM8Z Veteran Member
    8,889
    232
    May 19, 2000
    Los Angeles
    Guys,
    Very much appreciate the photos and reaearch!!
    This will come in very handy when I get done with the brakes and start looking at this steering shaft project.
  5. largestar
    largestar Member
    50
    9
    Nov 21, 2017
    I have replaced many rag joints with borgensons shafts. They can or do make about anything you would want. If anyone is on the fence about this upgrade do it. Much improved.
  6. ULTM8Z
    8,889
    232
    May 19, 2000
    Los Angeles
    Are you running one on a 2nd gen with a standard size steering box? If so, which one are you running?
  7. largestar
    largestar Member
    50
    9
    Nov 21, 2017
    I am not currently but will be soon on my 81 z. you can order a kit or the pieces from summit. I would call borgeson and tell them what you want and get a part number, then price shop. I'm convinced one of these shafts saved my life in an old dodge pickup. Most folks don't realize how much feedback you lose with a ragjoint.
  8. kphedges707
    kphedges707 New Member
    Apr 14, 2012
    Clarksville
    largestar likes this.
  9. Rayden2009
    59
    May 12, 2016
    Calgary AB
    Wow thats cheap. Glad it worked out for you.
  10. ULTM8Z
    8,889
    232
    May 19, 2000
    Los Angeles
    Ok, so I'm starting to get serious about this...
    I found the p/n on my AGR box and it's a 292117. It has the 13/16" 36 spline input shaft.
    http://www.steerco.com/product-p/292117.htm
    Now, when I go to Summit, I see the Borgesen joints for this size input shaft, but many of them have this other specification of 3/4" DD.
    Anyone know what this 3/4" DD means?
