intake manifold
Discussion in 'Tips 'n' Tricks Topic' started by CHEVYNICK58, Nov 11, 2015.
  1. CHEVYNICK58
    CHEVYNICK58 New Member
    23
    Nov 2, 2015
    spokane washington
    I have a chevy small block aluminum manifold and want to strip off the black paint does anyone have a good way to strip it?
  2. CorkyE
    9,054
    173
    Just plain paint? Chemical stripper will be easiest, then power wash. Media blast will probably look better.
  3. tom3
    tom3 Veteran Member
    10,769
    81
    Aug 1, 1999
    ohio
    Factory intake black of some sort? Could be hard to strip with chemicals. Blasting might be the only solution? Then getting all the blast media out of it is a chore that has to be done perfect. Might try some lacquer thinner, keep it wet for a while. Sometimes that baked on paint will come off, sometimes it just won't.
  4. gin man
    gin man Veteran Member Gold Member
    2,018
    Feb 24, 2002
    Morris, Il
    I tried something called CitriStrip that worked very well and wasn't as harsh as normal paint remover. I got it at Home Depot although I assume you can get it elsewhere.
  5. muscl car
  6. 408maro
    408maro Veteran Member
    1,618
    Nov 27, 2008
    San jose,CA
    Paint stripper from parts store. I used a few different ones but Napa brand works pretty good
  7. Twisted_Metal
    25,461
    348
    Are you wanting a nice, clean bare aluminum manifold when you're done?
    Once it's painted... stripping it completely clean is very difficult.
    Oven cleaner works but it will discolor the aluminum if left on too long.
    (Then.. You're looking at repainting it for sure.)
    I've used citri-strip on several old metal parts and found it worked quite well.
    Once it's cleaned of paint.... Wipe it down with mineral spirits, spray it with aluminum paint and clear it.
    Then be EXTREMELY careful about getting gas on it.
  8. Burd
    442
    71
    Oct 6, 2011
    Detroit Mi
    I believe crushed walnut shells were used on a part I had restored at a Corvette shop. It didn't change the Patina. I had a dist for my buddy's 70 Z done like this too.
  9. bfendick
    bfendick Veteran Member
    141
    Dec 3, 2006
    Vernon, BC
    I had aluminum rims shot with glass beads and they came out very nice and smooth but then need to reseal with clear coat, should work with the intake.
  10. hogg
    hogg Veteran Member
    3,129
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    when using stripper cover whatever with plastic sheet after aplaying the stripper. Will let the stripper stay wet longer so it can work better, longer.
