Installing EFI
Discussion in 'Electrical Systems' started by 73rsltrox, Mar 8, 2018.
  1. 73rsltrox
    73rsltrox New Member
    Nov 7, 2017
    Hi any info would be awesome. What wire when the ignition is turned on stays hot even while cranking? I need to find this for the ECU connection. Thanks.
  2. 8pack
    2,390
    72
    Aug 29, 2007
    Pittsburgh, PA
    If you have an electric choke, that one.....
    73rsltrox likes this.
  3. Green hornet
    Green hornet Veteran Member
    1,314
    193
    Oct 11, 2015
    North Bay, CA
    You could run a new wire directly from the ignition lug on the fuse box.
  4. ULTM8Z
    ULTM8Z Veteran Member
    8,669
    155
    May 19, 2000
    Los Angeles
    The + side of the coil has to stay hot during cranking otherwise the engine wouldn't fire.
