Install and use an air/fuel ratio gauge for nitrous.
Discussion in 'High Tech Retrofits' started by slayer021175666, Feb 12, 2018.
  1. slayer021175666
    slayer021175666 Veteran Member
    1,213
    57
    Feb 29, 2016
    Idaho
    I'm just wondering how to set up the gauge and sensor (or SENSORS) in an old small block or if I should even do it. If I'm correct, it seems like there might be a double advantage. Not, just knowing the air/fuel ratio when spraying but, also, just using the gauge for general engine tuning. I already have a vacuum gauge installed. I use it quite a bit for tuning and monitoring. Is there any advantage to having an air/fuel gauge, too?
    Thanks
  2. 80sz
    80sz Veteran Member
    2,861
    311
    Feb 2, 2014
    Buffalo,n.y.
    They are nice but not a substitute for reading plugs. They help in the overall decision of tuning.
  3. CorkyE
    9,716
    298
    Yep, learn to read your plugs.
  4. slayer021175666
    1,213
    57
    Feb 29, 2016
    Idaho
    I realize you still need to read the plugs.
  5. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    651
    19
    Aug 18, 2011
    Upstate New York
    I would ONLY read the plugs.
