Inner window felt guides
Discussion in '1970 - 1973 Specific' started by Petescamaro, Feb 26, 2018.
  1. Petescamaro
    Petescamaro Member
    84
    Aug 16, 2014
    ACT
    Hi
    Could some pls advise me if there meant to be 3 or 2 inner window felt guides. I removed both of my door panels and noticed that booth only have 2 inner felt guides on each side., been middle and rear on both doors. If only 2 are the locations correct.
    Thanks
  2. COPO
    16,519
    301
    Yours is correct.
  3. Petescamaro
    Petescamaro Member
    84
    Aug 16, 2014
    ACT
    Thanks
  4. Ote
    Ote Member
    55
    Sep 24, 2017
    In addition to the two felt guides at rear and middle, there is also what looks and mounts like a felt guide in the front, but without any felt. It's used to locate and hold the upper door panel tight against the door.
  5. FlaJunkie
    6,065
    113
    Mar 24, 2001
    Rockledge, Florida
    On a 1970, there is only one felt covered hanger(3), in the center of the top of the door. The other two on the ends(2) are un-felted, and used to hold the inner top door trim with the inner felt piece in place on top of the door.
