info for a parts washer
Discussion in 'Garages, Workshops & Tools' started by 5spd540, Nov 24, 2012.
  1. speed_m5
    speed_m5 Veteran Member
    1,053
    13
    Apr 17, 2010
    Baytown Texas
    I bought a larger one of Craigslist from a closed down shop, it has a full size 55 gal drum under it. I adjusted the pump to sit about half way up then fill it up with water to about 5" below the suction of the pump. added 20 of mineral spirits on top of the water being they will not mix. now all the heavys fall out into the water and the suction stays free and clean. when comes time to clean it out i pump all the mineral spirits into clean 5 gal pals till i lose flow. I lower the pump to get the last little bit out then just change out the water in the btm real easy to do
  2. Philip
    Philip Veteran Member Lifetime Gold Member
    1,806
    May 30, 2006
    Marana, AZ
    Here is mine, the pump was froze up today. First time it was turned on in a few months. Had to spin the impeller a little to jump start it and it started working again.
  3. 57Plymouth
    57Plymouth Veteran Member
    1,078
    Jul 31, 2001
    Blythewood, SC
    I've been using mineral spirits in mine for a few years. It gets dirty, so I change it out when it gets pretty black. The first stuff I used was a biodegradeable cleaner from Northern Tool which smelled like dirty diapers and wouldn't wash spit off a bolt, much less dirt or grease.
  4. 5spd540
    12,344
    12
    Sep 19, 2009
    Guyton, GA
  5. 5spd540
    12,344
    12
    Sep 19, 2009
    Guyton, GA
    I use POR-15 fluid in mine
  6. dkcamaro
    dkcamaro Veteran Member Lifetime Gold Member
    Be sure not to use the water based cleaners in your machine, they will rust your machine. You can buy chemicals through Car quest or your local parts store. Or as others have quoted here
  7. POS71RS
    POS71RS Moderator Staff Member Lifetime Gold Member
    10,321
    Aug 21, 2002
    Central Coast, CA
    That's friggin brilliant.
  8. Johnny Blaze
    Johnny Blaze Veteran Member
    911
    21
    Jan 24, 2013
    New Washington, IN
    AS in "Marine Clean"?
  9. CamaroDoc
    CamaroDoc Veteran Member
    1,828
    37
    Sep 13, 2003
    Skiatook, Okla. 74070
    I use kerosene in a retired Safety-Kleen unit like this one. Just dirtier....
    :bowtie:
