if you run the master cylinder dry, do you need to bench bleed?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 79rallysport, Jul 8, 2007.
  1. 79rallysport
    79rallysport Veteran Member
    976
    Feb 11, 2003
    Vestal, NY
    I was bleeding my brakes today and I ran the master cylinder dry. Do I need to bench bleed the MC now?
  2. tom3
    tom3 Veteran Member
    11,319
    191
    Aug 1, 1999
    ohio
    Sometimes you can fill the cylinder, let it sit overnight, and any air will find its way up and out. Worth a try.
  3. BonzoHansen
    Try gravity bleeding it....but you may be SOL.
  4. Knuckle Dragger
    Knuckle Dragger Administrator Staff Member Lifetime Gold Member
    13,880
    738
    Nov 2, 2002
    Waddell AZ
    Good answer right there. Sometimes no and sometimes yes. If it was dry too long and moved too many times you could have damaged the seals. The only way to know is to try it.
  5. 1FstChevy
    1FstChevy Veteran Member
    1,773
    Nov 24, 2005
    Buckeye State
    Excuse me not knowing this... but what do you mean by bench bleed? is this a fancy term for a rather common job? Also... you spoke of damaging seals if the MC is dry too long, how does this happen? and if I recently purchased a 4th Gen MC that I might be using for my new brake setup does it make a difference whether it has residual fluid in it or is completely dry?
    Thanks for the clarification...
  6. kik_start
    kik_start BANNED
    3,296
    Sep 3, 2006
    gone crazy
    From what I understand... the reason for "bench bleeding" in the first place is to get the MC level. If installed it tilts back and there are two small areas that can trap air and never get it all out.
    I would at least jack the car up high enough in the rear to get the MC level and bleed it. IMO
    I'm sure someone will tell us if I'm wrong...
    Here is an illistration where the air gets traped and can cause rust and a soft pedal.
  7. Knuckle Dragger
    13,880
    738
    Nov 2, 2002
    Waddell AZ
    A bench bleed is just that, working the air out of the assembly on the bench. There are a couple of ways to do it. Put lines from the outputs up into the reservoir and manually activate the master until the air is gone. Or plug the ports and depress the plunger in and out until it's rock solid, or you no longer see tiny bubbles coming up from the bottom of the reservoir.
    As long as you haven't been pumping the in a feverish pace with the master dry the seals should be OK. If it's been sitting a long time of course you may have seal issues, they are just rubber.
  8. 1FstChevy
    1,773
    Nov 24, 2005
    Buckeye State
    Alright that makes sense, perhaps people I know just don't use that term... and the master has only been removed from the T/A donor for approx. 2 months, and had brake fluid coming out of it when it was tilted at various angles, so it should be fine!
    So any particular procedures I should follow regarding the brake fluid once I have the new master and lines run?
  9. kik_start
    kik_start BANNED
    3,296
    Sep 3, 2006
    gone crazy
    Bench bleed, then bleed lines keeping the MC full at all times starting with the right rear wheel (farthest to closest).
  10. jayb53guy
    jayb53guy Veteran Member Gold Member
    1,813
    May 10, 2006
    Niceville, FL.
    I have found that cracking open the line right off the master cylinder and giving it a few good pumps will get rid of some of the air that might be trapped in the MC. Then tighten them up and bleed it normally from the right rear working forward.
    Good luck--
