Ideas for cable box with wall mounted TV
Discussion in 'The BS Topic' started by XxWickedz28xX, May 9, 2010.
  1. XxWickedz28xX
    XxWickedz28xX Veteran Member Lifetime Gold Member
    5,981
    May 22, 2001
    Carmel, NY
    We have a wall mounted flat panel TV in our bedroom, and the cable box was sitting ontop of my dresser for years. We just got new furniture, and that just wont work anymore.
    So Im looking for ideas on what to do with the box. Its a Comcast DVR, so its pretty bulky compared to others Ive seen.
    Anyone using a remote extender? Ive also seen some DVR wall mounting kits, but they seem to stick out too far and look gawdy(sp?)
    Just looking for ideas. What'cha guys got?
  2. Earlsfat
    Earlsfat Veteran Member Lifetime Gold Member
    1,504
    Jun 14, 2006
    Whut?
    Nuttin. I'm looking to do something similar and my big fat head can't come up with a single idea on what to do with that box.
  3. ATM
    ATM Veteran Member Lifetime Gold Member
    2,265
    Oct 10, 2009
    Morris, Illinois
    I installed a 52" TV at my Brother In Law's house, and the mount he got was sort of scissor like-ish, you could pull it out from the wall, turn it, tip it, you name it. The bottom of the wall mount had an accessory you could mount to it that was a shelf you could set your components on. It had a channel that you could hide the wires inside of leading to the TV. I put the electrical and cable out let behind the TV in the wall so nothing was visible.
  4. mach158
    mach158 Veteran Member
    2,925
    Aug 7, 2001
    Marion, Iowa
    Put the box in a closet or in another room and run the cable from there?
  5. Javelin3o4
    Javelin3o4 Veteran Member Lifetime Gold Member
    1,852
    Apr 21, 2004
    Concord, CA
    Duct tape it to the back of the TV.
  6. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Wires not cleaned up yet after install.
    This was my first mock up after I mounted everything.
    It's all cleaned up and centered now, but this gives you a basic idea.
    If you want good idea, goto http://www.avsforum.com/avs-vb/ and check out some of the setups.
  7. sikzdrivr
    sikzdrivr Veteran Member
    699
    Jul 17, 2003
    canada
    Depending whats on the rear wall (perhaps a big enough closet) you could build in a cubby if ya want a cleaner look. I did that to house my avr and amps cable bx etc.
  8. XxWickedz28xX
    5,981
    May 22, 2001
    Carmel, NY
    WOW, those racks can hold some weight! I think this is my best/easiest option.
    Ace, how far do the boxes sit out from the TV? My TV is about 8" from the wall at the top and the box sits out about 15", which means half the box will be sitting beyond the TV.
  9. green 1977
    green 1977 Veteran Member Lifetime Gold Member
    3,705
    47
    Aug 18, 2003
    On Wisconsin!
    how did I know Ace would have pictures of a huge rack
  10. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
