HP gains from just a valve job?
Discussion in 'High Performance Modifications' started by need-for-speed, Oct 17, 2017.
  1. need-for-speed
    need-for-speed Veteran Member
    638
    Feb 7, 2003
    Conroe, TX
    I've been curious if it's worth it to port my Edelbrock performer heads. It's only a 5500 - 5800 rpm motor. So I called the machine shop and the guy laughed at my little heads. He said I probably wouldn't want to spend a thousand $ for porting those small heads. (he might be right)
    He said I might be able to pick up 25 HP +/- with a valve job. I think the eddy heads already have a 3 angle valve job.
    I do plan to at least have a valve job done (I have one bent exhaust valve and need new springs).
    Anyone know how I might pick up HP with just a valve job?
  2. Mwilson
    Mwilson Veteran Member
    My machine shop ( Steve Ashworth Performance ) claims incredible flow increase and horsepower but they cut the seat/head all the way in then do the valve job. He said I left a lot on the table doing the basic 3 angle but I didn't have the cash at the time.
  3. mrdragster1970
    A radius valve job gives better flow, move the seat way out to the edge gives better flow, but shortens the valves life.
    Cleaning up around the seat also can help flow.
    There's stuff that can be done, but as mentioned, is it worth it on such a low powered combination???
    Hell look at the $1,000 of dollars some guys spend on 5 HP or to save 10 lbs.
    Good luck fixing your damage!!!!
  4. Lowend
    14,337
    242
    Mar 25, 1999
    San Jose, CA, USA
    Unless the heads are off for some other reason, I would put the money somewhere else.
  5. 77 cruiser
    77 cruiser Veteran Member
    475
    14
    Nov 17, 2006
    Frostbite Falls MN
    If you have them off get some porting done along with the valve job.
  6. mrdragster1970
    He's got a bad valve & needs springs.
  7. COPO
    16,276
    245
    I would buy better heads.
    Plant Engineer likes this.
  8. need-for-speed
    638
    Feb 7, 2003
    Conroe, TX
    mr dragster is correct. I have already pulled the heads. I called one machine shop and he laughed at my little Edelbrock heads and said it would be a waste of money to port them. I think he was just being a dick.
    So far not having a lot of luck finding a place to take them. Since I have the heads off I’m thinking of removing the valves and porting them myself and then let a shop machine the valves replace the springs and reassemble.
    I would be doing very minor ie. bowl blend/ stage 1 - since I don’t want to raise the RPM band. I’m pretty handy with tools. Question is can I learn by watching videos and such. I’ve learned a lot from them for other tasks with great success.
  9. need-for-speed
    638
    Feb 7, 2003
    Conroe, TX
    You sound like the machine shop guy LOL (without being a dick, of course) I rarely drive this car so I don’t think I want to spend the money for different heads. Also this motor has a cast rotating assembly so I don’t really even want to spin it faster than 5500 RPM
  10. Lowend
    14,337
    242
    Mar 25, 1999
    San Jose, CA, USA
    If the heads are off... polishing the exhaust port is easy and will yield some gains.
