How:tube flare for hose?
Discussion in 'Tips 'n' Tricks Topic' started by badazz81z28, Aug 25, 2015.
  1. badazz81z28
    14,177
    110
    Las Vegas, NV
    Anyone have a tip on how to create the nipple end on a steel tube so I can push and retain a rubber Hose?
  2. COPO
    15,966
    186
    Depends on the dia of the tube. If it's fuel line dia then you need a flaring tool.
  3. Camaro75LT
    Camaro75LT Masshole Staff Member Lifetime Gold Member
    6,570
    59
    May 17, 2001
    Boston-ish
    I'm having trouble picturing what flair end you are looking to accomplish. One of the hard line to quick connect fittings or just a barbed end to connect a standard rubber line?
  4. badazz81z28
    14,177
    110
    Las Vegas, NV
    Yes, I just want to barb the end. That way I can slide a hose on and clamp the hose on
  5. Camaro75LT
    6,570
    59
    May 17, 2001
    Boston-ish
    I have used a double flairing tool to make the hard line have something for the rubber line to attach to. Just flair the line once (as is don't compete the double flair). Two hose clamps on the connection and done.
  6. pajeff02
    pajeff02 Veteran Member
    118
    Aug 16, 2015
    Mansfield, PA
    ^^ This. You can probably "rent" a flaring tool from any of the chain parts stores. If you invest in one, get a quality tool as the cheaper ones often do not hold the tubing real well and the crimps are not as precise.
  7. mickstan
    mickstan Veteran Member
    927
    Jun 11, 2012
    E'ville, IL
    You need a good one for using on stainless. Most are made for copper!
  8. badazz81z28
    14,177
    110
    Las Vegas, NV
    That's my fear. The autozone version may work, despite no way of holding it for a good flare.
  9. mickstan
    927
    Jun 11, 2012
    E'ville, IL
    If you have a vise, you can mount it in there so you get a good hold on it.
