How to remove tar from floors??
Discussion in 'Tips 'n' Tricks Topic' started by Protour-Camaro, Apr 6, 2014.
  1. Mike76Rally
    Mike76Rally Veteran Member
    487
    Jan 6, 2013
    Canon City, CO
    sweet i'll get the carpet sticky and go at it, thanks
  2. Protour-Camaro
    Protour-Camaro Veteran Member
    2,117
    Feb 16, 2012
    California
    Yeah...and will take off paint!
  3. CamarosRus
    CamarosRus Veteran Member
    KEROSENE !!!!!!!!!!!!!!!
  4. convman1960
    convman1960 New Member
    17
    Nov 9, 2015
    Kansas City Kansas
    wd 40 is great for removing tar off the outside of the car i would assume it would work on the floor pan just dont use it in a paint area or the painter will shoot you lol
  5. Zspoiler
    Zspoiler Veteran Member
    2,745
    164
    May 6, 2012
    Federal Way, Washington
    Use a paint scaper. Its all sorts of "fun". But if you can`t afford chemicals.Then you will just have to use good old fashion "elbow grease"
  6. Bandit723
    Bandit723 Veteran Member
    2,690
    328
    Oct 1, 2016
    Waupaca WI
    I found that Klean Strip Prep All "wax and grease remover" works well and will not take your paint off.
  7. camaro71/holland
    1,029
    40
    Aug 27, 2003
    The Netherlands
    Grinder with a thick, metal wire wheel, works like a champ in an empty shell. Need to cover interior otherwise it will be all over the place.
  8. xten
    xten Veteran Member
    1,798
    832
    Sep 24, 2014
    Pittsburgh, Pa.
    For the rust and scrapes, Chassis Saver or POR 15 with a brush.
  9. COPO
    16,576
    307
    Since they are plastic, you can use a windshield ice scraper to scrape the tar off.
