How to remove tar from floors??
Discussion in 'Tips 'n' Tricks Topic' started by Protour-Camaro, Apr 6, 2014.
  1. Protour-Camaro
    Protour-Camaro Veteran Member
    2,117
    Feb 16, 2012
    California
    I'm trying to get the risidual tar left over from the factory sound deadener off the floor pans. Any ideas on how to do this without destroying the paint?
  2. COPO
    16,697
    346
    Pre-Kleano or Kleen-Flo Tumbler from NAPA. Body shops use it and it's in a 1 gal can. Used to remove wax and silicone off car bodies and also over spray but does not remove paint from the body. I've been using this for about 30 yrs but can no longer get it in Canada.
    Lots of products out there that remove wax/grease/silicone
  3. Protour-Camaro
    2,117
    Feb 16, 2012
    California
    Thanks! Any suggestions for paint touch for the areas I did scratch? I do have some slight surface rust I will clean up too.
  4. COPO
    16,697
    346
    If yours is a Norwood car with the red oxide primer, you could get the formula from this site and see if Napa can make you a rattle can for your touch ups.
  5. Protour-Camaro
    2,117
    Feb 16, 2012
    California
    No, its a Van Nuys and is body color. I don't mind painting it black or anything else as it will be covered. Just want something durable that will protect.
  6. Mike76Rally
    Mike76Rally Veteran Member
    487
    Jan 6, 2013
    Canon City, CO
    On this topic, I got some new sound deadener stuff about to be installed in mine, do you need to remove the residual left over from the factory adhesive or will the new stickiness adhere well enough without removing it?
  7. Mike76Rally
    487
    Jan 6, 2013
    Canon City, CO
    bump....any answer to the above question?
  8. COPO
    16,697
    346
    The sound deadener doesn't slide around once the carpet is down so it really doesn't matter if it sticks. When I removed the factory deadener, none of it was sticking.
  9. 7dcamaro
    7dcamaro Veteran Member
    273
    Apr 10, 2012
    Warner Robins, GA
    Brake cleaner and a rag .......works like a champ.
  10. COPO
    16,697
    346
    Brake Cleaner is pricy up here.
