how to raise driver seat?
Discussion in 'Interior Restoration' started by phat80, Nov 2, 2017.
  1. phat80
    phat80 Veteran Member
    1,019
    9
    Jan 4, 2013
    Victoria BC
    1980 'Maro, since I put on my 2" cowl hood I feel like I'm sitting down in a hole. I can't see nothin'. So I want to raise my seat. Today a played around installing stacks of fender washers until I got the height I want.
    I'm going with a 1" raise, by the time I get the new carpet in that should do the trick. Obviously I can't just use a stack of fender washers as a permanent solution, so if one of you kids can offer some spiritual insight on making a bracket that would be greatly appreciated.
  2. 70-camaro
    70-camaro Veteran Member
    1,241
    162
    Mar 25, 2010
    marietta ohio
    Maybe 1 inch box tubing? Although it is measured by the inside.
    Turbo70Camaro likes this.
  3. ol' grouch
    ol' grouch Veteran Member
    1,586
    338
    Jul 4, 2013
    Evansville, In.
    Back in the day I used some pieces of 1X2 wood with holes drilled for longer bolts. I even trimmed them in wood shop in school so there would be a slight backwards slant.
  4. Scott51
    Scott51 Veteran Member
    472
    30
    Jan 2, 2012
    New Zealand
    I found the same thing with a 4" cowl hood so raised my driver's seat about a 1/2" with spacers made of thick aluminium flat bar under each mount.
  5. budro6968
    budro6968 Veteran Member
    2,174
    292
    Apr 2, 2016
    Jax Florida
    Electrical conduit with washers tacked on either end to keep them from sliding. I saw that in an old truck with a Caddy seat.
  6. cadmanmeg
    cadmanmeg Veteran Member
    1,753
    Mar 20, 2006
    Bothell, WA
    kids booster seat? :D
