HOW MANY TURNS
Discussion in 'Troubleshooting & Diagnosis' started by joe acosta, Nov 25, 2002.
  1. joe acosta
    joe acosta Veteran Member
    TO ADJUST A TWO BARREL CARB AIR/FUEL MIXTURE SCREWS HOW MANY TURNS OUT
  2. Eric
    Eric Veteran Member Lifetime Gold Member
    #1 STOP SHOUTING
    #2 There is no "set" number of turns- it is dependent on the carb/engine setup and state of wear- try 2-3 turns 'out' and go from there- you will then need to use either a low rpm tach or a vacuum guage to set it up optimally for your particular application.
  3. Stans80V6
    Stans80V6 Veteran Member
    2-1/2
    Been there; done that; can't remember!
