How long do I let RTV cure before adding fluid?
Discussion in 'The BS Topic' started by 72CamaroSS, Jan 16, 2010.
  1. 72CamaroSS
    72CamaroSS Veteran Member Lifetime Gold Member
    1,660
    Mar 10, 2005
    Winston-Salem, NC
    I just changed the tranny filters on the wife"s Durango. You use RTV instead of a gasket. Just wondering how long I should wait to put the tranny fluid back in. As always, thanks all.
  2. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    It doesn't say on the tube ??
    I always thought the general rule of thumb to be safe was 24 hours.
  3. Phil G
    Phil G Veteran Member
    684
    16
    May 3, 2004
    Tucker, GA, USA
    I like to let RTV cure overnight (and I usually use the DOW 732 industrial stuff) but you could probably go ahead and refill the fluid and drive it in the morning...
    YMMV...
    :cool:
  4. 72CamaroSS
    1,660
    Mar 10, 2005
    Winston-Salem, NC
    Nope, just said cures in an hour and dry in 24 hrs. But I wasn't sure when it was safe to put the fluid back in. Most cases you don't have a full 24 hrs of down time. Guess I will put it off till the wife has to go to work tomorrow evening. Thanks guys.
  5. 67lemanster
    67lemanster Veteran Member Lifetime Gold Member
    12,661
    Oct 20, 2003
    I AM ILK
    for front covers, oil pans and intakes(ie replacing a cam) when i have the motor buttoned up its getting fluids and is gonna be started. figure the intake with the front and back bead is the last use on a cam swap. and once i let the rtv setup i would say it takes about an hour to an hour and a half to get the intake, carb, fuel lines, coolant hoses, oil in the motor and anything else i forgot. i havent had any leak because of not curing long enough.
    so 1.5 hr.
  6. krabben1
    8,053
    May 16, 2007
    ( . Y . )Delco
    Yeah,things dont sit in shops for a day before getting filled and started.Ive always done it within the hour.Usually as long as it took to get things back together and get done.
  7. spoonLT1355
    spoonLT1355 Veteran Member Lifetime Gold Member
    5,511
    Mar 1, 2003
    Rockledge Pa
    We have filled trannys up with-in 1/2 hour after using RTV and have never had a problem. Just make sure everything is CLEAN.
  8. Spot_remover
    Spot_remover Veteran Member Gold Member
    853
    Aug 24, 2008
    Murrayville.Ga
    Us too
  9. JOHNNYMO
    JOHNNYMO Veteran Member
    another reason to never buy a Mopar product....:rolleyes:
  10. 72CamaroSS
    1,660
    Mar 10, 2005
    Winston-Salem, NC
    I know, always wondered about that. Don't know what they have against gaskets..........
