How do you remove the wiper arm
Discussion in 'Troubleshooting & Diagnosis' started by RS1979, Oct 4, 2017.
  1. RS1979
    2,914
    369
    Jun 18, 2013
    Memphis, TN
    I want to remove and repaint my wiper arms but I can’t figure out how to get them off. How do they come off?
  2. Rdobbs1977
    Rdobbs1977 Huge Guns N Roses Fan
    283
    10
    Dec 1, 2014
    Nashville
    they do make a tool for them. i only know this because i was thumbing through a tool catalogue yesterday as i have yet to remove a wiper arm..
  3. RS1979
    2,914
    369
    Jun 18, 2013
    Memphis, TN
    I found a clip or retainer on them. I used a screwdriver to move it away from the shaft but couldn’t move it far enough to release the arm.
  4. David79Z28
    1,276
    38
    Oct 22, 2009
    Greenville, TX
    I was just trying to do the same thing.
    Following...
  5. Green hornet
    Green hornet Veteran Member
    1,260
    184
    Oct 11, 2015
    North Bay, CA
    The retainer doesn't move far. Grab the wiper arm as low as you can to the base. Now rock it back and forth til it comes loose. This is how I have remove them for years. Be patient it will work loose.
  6. 70 Proof
    70 Proof Veteran Member
    382
    26
    Sep 28, 2014
    Southern Utah
    The attached pics are of a universal tool to remove wiper arms from the splined shaft. Cost about $7-$10.
    Careful not to pry against the windshield.
  7. budro6968
    budro6968 Veteran Member
    2,179
    293
    Apr 2, 2016
    Jax Florida
    Get a Q Tip with some PB blaster and soak it and dab the base let it soak in. Then rock it off. You could use a heat gun or blow dryer to warm it up, might help.
  8. Twisted_Metal
    25,757
    445
    Do NOT lean a metal tool on the edge of the windshield.
    I did that 25 years ago and made a tiny chip in it.
    A week later, a crack had formed from that chip and ran halfway across the windshield. :(
    But the new (insurance paid) glass looked great! :D
  9. Gary S
    21,082
    308
    Get that simple tool. It is cheap and available at any decent auto parts store. That tool makes it easy because it unloads the preload of the spring so the wiper comes off easily without messing anything up. The preload of the spring is what makes it difficult to lift the wiper off its splines.
  10. RS1979
    2,914
    369
    Jun 18, 2013
    Memphis, TN
    Yeah I found that tool at the parts store. It made it easy. Thanks for the info guys:)
