How did I screw this up?
Discussion in 'Troubleshooting & Diagnosis' started by zekefreak, May 27, 2010.
  1. Philip
    Philip Veteran Member Lifetime Gold Member
    1,806
    May 30, 2006
    Marana, AZ
    I went and pulled all of my I/S I could find. There is an early and late design. One of the later designs is marked as having been removed from a 75. You may just have the wrong I/S. If so and you can not find one locally let me know and I'll send you one of mine.
  2. zekefreak
    zekefreak Veteran Member Lifetime Gold Member
    1,533
    Apr 16, 2006
    western PA
    Shazzam, shazzam, shazzam!!! I think you have solved the mystery. I never knew there were 2 different I/S. Mine is like the upper one in your pic. As you're sitting in the car, the shaft bolt is on the left side and the flange bolts are at 3 & 9 o'clock.
    But where your pins are on the upper pic, mine has been cut off or were never there to begin with.
    So now back to an earlier question, where can I find an I/S?
  3. Philip
    1,806
    May 30, 2006
    Marana, AZ
    What year is your car?
  4. Philip
    1,806
    May 30, 2006
    Marana, AZ
    BTW if they made 2 different intermediate shafts then there are also 2 different steering column shafts. Did you change either one?
  5. zekefreak
    1,533
    Apr 16, 2006
    western PA
    Its a 79 and I never changed either, but I bought the car in '94 so who knows what has been done to it!
  6. Philip
    1,806
    May 30, 2006
    Marana, AZ
    Most GM cars went to the double D shaft in 79. The X body didn't but it was the last year for that style, can not say for sure on the F body. The column in my car is from an 82 Eldorado (tilt/telescopic) so I used an I/S with the double D.
    If that lower shaft in the photo will solve your problem you can have it for the cost of shipping. PM your address and I'll send it out Tuesday.
  7. Philip
    1,806
    May 30, 2006
    Marana, AZ
    Has it been that way since 94?
  8. zekefreak
    1,533
    Apr 16, 2006
    western PA
    Yes, I took a long time the restore it, its only been on the road for a couple years. My steering wheel was centered at about 2 o'clock but I thought that would be fixed with an alignment. Well, the alignment went the other way and things are as you see. I'll pm my address.
  9. Philip
    1,806
    May 30, 2006
    Marana, AZ
    I'll box it up and drop it off Tuesday and PM you with the cost.
    Now I am going to bed.
    I about doubled my post count just in this one thread :D
  10. 70SSVROOM
    70SSVROOM Veteran Member Lifetime Gold Member
    351
    Apr 14, 2004
    NorCal
    great job on the pics Philip
