How did I screw this up?
Discussion in 'Troubleshooting & Diagnosis' started by zekefreak, May 27, 2010.
  1. zekefreak
    zekefreak Veteran Member Lifetime Gold Member
    1,533
    Apr 16, 2006
    western PA
    I have been having problems with front end alignment and steering wheel alignment. Here is the issue: With my front tires straight and both tie rod assemblies at equal length, my steering wheel is 90* off center. Even when I center the steering by lock to lock, the top of the steering wheel is at 9 o'clock. I have replaced the rag joint and I even took apart the column housing (never removed the column from the car) for painting. What did I do wrong? Thanks.
  2. GetMore
    2,870
    Nov 8, 2004
    Patterson, NY
    I think someone said that the rag joint can be installed 90° off. You may want to see if you can move it there. I messed with mine more than a year ago, so I don't remember if there were four flats on the box or just one.
  3. zekefreak
    1,533
    Apr 16, 2006
    western PA
    I don't think I can move the rag joint 90*. It would be either 0* or 180* and it attaches to the steering box only one way.
  4. Camaro11
    Camaro11 Veteran Member
    2,669
    Jul 10, 2003
    Atlanta, GA, USA
    You can always pull the pitman arm on the steering box (a splined shaft I believe), rotate the wheel to the correct position, and put the arm back on the output shaft.
  5. BondoSpecial
    8,695
    Sep 20, 2004
    Southern Maryland
    You don't want to make more turns lock to lock, to one side than the other though, if the pitman arm is already centered.
  6. global warmer
    global warmer Veteran Member
    494
    Apr 1, 2010
    Saratoga Springs NY
    can you pull the wheel off and move it one bolt hole to the left???
  7. zekefreak
    1,533
    Apr 16, 2006
    western PA
    No, the steering wheel only goes on one way. There is a line stamped in the middle of the shaft that aligns with the top of the steering wheel and it is pointing to 9 o'clock.
  8. steve_1978
    steve_1978 Veteran Member
    376
    May 5, 2010
    ontario canada
    well everybody has said everything i can think of, so if all else fails get a bigger hammer
  9. zekefreak
    1,533
    Apr 16, 2006
    western PA
    Is it possible that the input shaft of the steering box is 90* off?
  10. global warmer
    494
    Apr 1, 2010
    Saratoga Springs NY
    I may have it I had a similar problem before and I had a slightly bent
    upper control arm any alignment shop can verify.
