? Houston place to repair fender rust
Discussion in 'The Great State of Texas!' started by Chuck71RS, Sep 25, 2017.
  1. Chuck71RS
    1,098
    31
    Nov 24, 2012
    Houston, Texas
    Anyone know where in the Houston area I can get the lower area rust-dents repaired (I have the patch panels)? Or am I just wasting time searching?
    Two shops declined after seeing the patch panel (or never wanted to do it in the first place). Another $100 per hour + materials with no time estimate. (No way)
    Another 10 hours at $125 per hour. (No way)
  2. larrylarry
    larrylarry Veteran Member
    1,460
    55
    Dec 22, 2011
    San Antonio Tx
    Front fender? Lower area behind the wheel opening?
  3. Chuck71RS
    1,098
    31
    Nov 24, 2012
    Houston, Texas
    that is the area Larry
  4. larrylarry
    1,460
    55
    Dec 22, 2011
    San Antonio Tx
    I had to replace mine like every 2 gen Camaro.
    It's double walled in that area an dirt/dust collects there an when it gets wet it stays wet, more like mud that doesn't dry. Mine rusted out only towards the outside not on the bottom so I was able to cut it out very carefully without removing any of the inner wall. I did have some rust pitting on the inner wall but I treated it & painted it before welding on the patch panel. It took a long time to weld the patch on because of heat warping, it has to cool down before continuing.
  5. speed_m5
    speed_m5 Veteran Member
    1,053
    13
    Apr 17, 2010
    Baytown Texas
    I know a guy in Pasadena that should be able to help
    text me 713-962-9659
    Patrick
  6. 1972_Z-28
    1972_Z-28 Veteran Member Lifetime Gold Member
    1,482
    42
    Oct 6, 2005
    Sugar Land, Texas
    This guy Pat (speed_m5) is talking about is excellent. Small shop but will get done correctly and back to you at fair and honest price and quickly.
