Hood Clearance Issue
Discussion in 'Troubleshooting & Diagnosis' started by janis80z28, Jun 26, 2017.
  1. Zspoiler
    Zspoiler Veteran Member
    The try one from a 1975 Corvette.That has an HEI.
  2. janis80z28
    janis80z28 Member
    78
    Mar 8, 2006
    Chesterland, OH
    I'll see if I still have my factory equipement or see if i can find some if i dont.
    Just got off of live chat with summit racing, not a ton of help but they suggested trying this. https://www.summitracing.com/oh/parts/sum-239422/overview/
    Might go that route if I cant get my hands on any factory stuff to try.
  3. Chuck71RS
    1,013
    24
    Nov 24, 2012
    Houston, Texas
    Unfortunately there is no easy solution. (And I might be in the same situation). Best guess is determine how much clearance is needed, buy a drop base with the needed clearance and knock an indent with a ball peen hammer to try and clear the electric chock. I have seen this suggestion a while back
    Can not place your location reference of ......"piece of metal right in the middle...." Are you referring to the center of the top half of the air cleaner? If so, a flat top element will get you some more clearance
    Maybe your body mounts have compressed? New ones would get some more clearance
    Call Edelbrock
  4. Zspoiler
    Jus think outside of the box. Look at the Vintage Racers,SCCA road race cars of our era. for ideas.
  5. RMTZ28
    RMTZ28 Member
    40
    Mar 29, 2015
    Alb. nm
    How about a slightly shorter filter. Look on eBay for 16" air filter etc. Then ask a for height.
  6. Zspoiler
    So does K & N filters.
  7. 80sz
    80sz Veteran Member
    2,279
    183
    Feb 2, 2014
    Buffalo,n.y.
    If you can get a shorter filter about 2" tall and still maintain a 1/2" of clearance from air cleaner lid from top of carb I'd go that route.
  8. Layne02
    Layne02 Member
    87
    Jun 25, 2013
    Georgia
    I just went through same issue. Had 9 inch oval cleaner on it, but even with a 2" filter it hit. Went with a 1 1/2" drop base with 3" filter and it clears. Just as a note, a 2'" on the drop base will not clear the carb throttle plate, have to use a 3".
