Homemade leakdown tester
Discussion in 'Tips 'n' Tricks Topic' started by COPO, Sep 3, 2015.
  1. COPO
    16,337
    264
    Don't forget the .040 orifice. You can get the drill bit from a hobby store. Fill 1/4"-1/2" with JB Weld. My orifice is in the connection just before the RH gauge.
  2. l16pilot
    1,588
    75
    Dec 13, 2004
    Hurlock, MD, USA
    Mark - What do you use to hold engine at TDC for each cylinder?
  3. COPO
    16,337
    264
    Once the piston is at TDC and slowly add the air with the regulator, the piston does not move. Leave the trans is neutral. I used a camera inside the spark plug hole to make sure it was at TDC so the valves are closed. Before I used to loosen all the rockers so I knew the valves were closed and I still used a camera to get the piston at TDC, but then I would have added time to set all the hyd lifters which I'm not thrilled about. I'd rather set solid lifters cause there's no up and down and spinning of the push rod BS. :)
  4. onovakind67
    onovakind67 Veteran Member
    4,654
    Jul 8, 2001
    Fairfield, CA
    Will my motor have more leakdown if I use a .030" drill?
  5. COPO
    16,337
    264
    The results will be the same even if you use a smaller drill. The leakage will just come out SLOWER on the RH gauge that's connected to the cyl than if you use a .040. The .030 drill is smaller. If you used for example a 1/16" or 1/8" drill bit to make your hole, and regulated 100+ PSI into the both gauges, then adjusted the L to 100 PSI, the R gauge would be leaking so fast that you wouldn't have time to see what the reading was.
    I use my compression gauge hose but unscrew the shraider valve when I use it for the leakdown test.
  6. onovakind67
    4,654
    Jul 8, 2001
    Fairfield, CA
    It would be just the opposite. You are comparing the pressure drop across the hole to the pressure drop across the leaks in the cylinder. A larger hole would result in the RH gauge reading higher, and your leakdown would appear to be smaller. That's why the size of the hole matters, and there is no real standard for that. I would use a rotameter.
  7. COPO
    16,337
    264
    The STD is .040. Search Google on orifice hole on leakdown testers. I didn't make it up.
  8. l16pilot
    1,588
    75
    Dec 13, 2004
    Hurlock, MD, USA
    Thanks Mark :)
  9. COPO
    16,337
    264
    You bet. And it doesn't matter if the JB weld is on the L or R side of the pipe when you go to assembling it.
