Holley OEM fuel tank module
Discussion in 'High Tech Retrofits' started by Stx 09, Jan 15, 2018.
  1. Stx 09
    Stx 09 New Member
    14
    Nov 16, 2012
    Texas
    largestar likes this.
  2. WASyL
    WASyL LS1 Bandit
    21
    17
    Nov 9, 2013
    Warsaw, Poland
    I bought SPECTRA PREMIUM/COOLING DEPOT GM203FI on Rockauto, fits right in. Still don't know on fuel pump LPH, but having new tank, with provision for return line where needed and EVAP/Vent is a cool thing for only 355$.
    best regards
  3. 1971CamaroGuy
    3,650
    131
    Oct 31, 2004
    Arkansas
    I was going to post this same thing when I first saw the thread..the Holley looks similar to my spectra fuel assembly.... I got the tank and pump for roughly the same price as the holley sender alone.
    pump on my spectra tank works fine, if I feel like I need to upgrade I will...but no issues at this stage
  4. badazz81z28
    15,433
    226
    Las Vegas, NV
    Looks like an OEM Fox body pump set-up, but even that tank has a baffle around the pick up. That set-up would work but you might have issues with low fuel levels and sharp turns
  5. SRGN
    SRGN Veteran Member
    589
    186
    Feb 20, 2009
    Central NJ
    I'd still run a surge tank with it.
  6. czizza
    czizza Veteran Member
    907
    25
    Jan 8, 2004
    N. Massapequa, NY, USA
    Looks like a nice part ... let me know how it works ... I have the external pump and to clean up the bottom of the car this would work perfectly.
  7. 67johnny
    67johnny Veteran Member
    141
    Apr 14, 2016
    vancouver
    Look forward to an update post install!
