Holley 4555 rebuild kit
Discussion in '1970 - 1973 Specific' started by Eaglefixer, Aug 10, 2017.
  1. Eaglefixer
    Eaglefixer Veteran Member Lifetime Gold Member
    1,574
    Feb 25, 2002
    Warner Robins, Ga
    Guess i should add that after i dropped it back down I disconnected the battery and took my Cell phone out of my Pocket. Then i removed the carb and place on table. When i took the bowls off there was no gas in either bowl. Any ideas what happen today?
  2. COPO
    16,340
    264
    If the carb sits without driving it, it takes no time with today's chit fuel to evap.
  3. Eaglefixer
    1,574
    Feb 25, 2002
    Warner Robins, Ga
    Well i've think i have decided to send off my carb to rebuild. Anybody have a recommendation where to send it?
  4. ronzz572
    1,839
    42
    Feb 8, 2007
    imperial pa
    I would send it off to Eric Jackson. He can either rebuild it for you or restore it and replate it. It will look and work like a brand new holley. phone #(937) 836-5927 email address is sales@vintagemusclecarparts.com
    Vintage Musclecar likes this.
  5. CorkyE
    9,375
    241
    Do you think you bumped the hot wire on back of the alternator with the fuel line? If not, pull your negative battery cable and start looking for a wire that has rubbed through somewhere.
  6. 70lt1z28
    1,970
    250
    Oct 3, 1999
    Beavercreek, Ohio, USA
    When-if you send it to Eric tell him your exact engine setup. Manifolds or headers, engine mods and altitude. He knows his stuff. Not cheap but good. Depending on miles it may need the shafts bushed.
  7. Eaglefixer
    1,574
    Feb 25, 2002
    Warner Robins, Ga
    Well I talked to Eric today about my Holley. Your Right Dave about being not Cheap. But will sent it to him.
  8. ronzz572
    1,839
    42
    Feb 8, 2007
    imperial pa
    Yes not the cheapest, but the end result is worth it. I have had 5 carbs restored by him. Everyone were perfect in every way.
  9. Eaglefixer
    1,574
    Feb 25, 2002
    Warner Robins, Ga
    Well, Just Shipped it off To Eric. Can't wait to get it back so i can drive my Z
  10. 70lt1z28
    1,970
    250
    Oct 3, 1999
    How did the carb turn out? Photos?
