Holley 4150 Discharge Shooter Size
Discussion in 'Troubleshooting & Diagnosis' started by 70RSZ28CAMARO, Nov 11, 2017.
  1. 70RSZ28CAMARO
    70RSZ28CAMARO New Member
    28
    Dec 19, 2003
    Long Island, NY
    I have a 1970 z28 with a 4150 with an aftermarket .28 discharge shooter installed. Car runs great but once in awhile I get a stall when coming to a stop after exiting a highway, etc. When I look down into the carb and open the choke plate, it looks like its hitting the nozzles on the shooter and not opening al the way. I have my stock .25 shooter and the nozzles are not as long. I'd like to change it out but was wondering if a .25 is ok for this carburetor ?
  2. COPO
    16,055
    201
    You said you have the stock shooter. Why wouldn’t it be ok? I’m running a 70 Z28 4-spd 4150 List 4555 and all is stock except for the power valves because of my roller cam and using the 25 pump discharge nozzle.
  3. 70RSZ28CAMARO
    28
    Dec 19, 2003
    Long Island, NY
    The.28 was installed when I put in Hedders and 2 1/2 exhaust so I thought I needed it thank you
  4. 70RSZ28CAMARO
    28
    Dec 19, 2003
    Long Island, NY
    The.28 was installed when I put in Hedders and 2 1/2 exhaust so Ithought I needed it thank you
