Holley 4 barrel leaking
Discussion in 'Engine Topic' started by bourbon_scotch, Nov 5, 2017.
  1. bourbon_scotch
    2,020
    52
    Jan 10, 2003
    USA
    I have a holley 4 barrel vacuum secondarys and its leaking bad all the way around. I've rebuild it once a long time ago and then stopped using it. I'm thinking its not even worth looking at. Just buy a new carb maybe something else?
  2. phat80
    phat80 Veteran Member
    1,019
    9
    Jan 4, 2013
    Victoria BC
    dried out gaskets...but I'm only guessing.
  3. roeville
    roeville Veteran Member
    1,097
    38
    Oct 9, 2000
    SF East Bay CA
    Modern gasoline is generally not good on early carb gaskets. You might be able to replace with a current kit and be good to go.
  4. 80sz
    80sz Veteran Member
    2,702
    268
    Feb 2, 2014
    Buffalo,n.y.
    New gaskets for bowls are 10.00.
  5. COPO
    16,399
    283
    New blue Holley gaskets don’t dry out. Remove both bowls and the mounting plate and using a machinist file, file the part the metering blocks mount to. You’ll be surprised how not true they are. Use oil while filing too. In ‘85 I spent about 1 hr on each side filing. After that it runs like it should.
  6. muscl car
    As said gaskets have dried out and shrunk which is causing seepage . throw another carb kit on it and youll be good
