Hillbilly's Rented Mule
Discussion in 'Project Progress' started by hillbilly75, Dec 29, 2013.
  1. Da-bigguy
    3,308
    70
    Jan 19, 2010
    Cypress, TX
    When I saw this pic, it made me think..."Holy cow, the car got scalped!"
    Looking fantastic!!
  2. hillbilly75
    hillbilly75 Veteran Member
    407
    Jan 7, 2011
    Nowheresville
    Coadster: Thanks man, nah not a trailer queen(unless it breaks then it goes on the trailer of shame) but I told the wifey I'm doing this once.... Then I'm beating on it.
    Da-Bigguy: Thanks! I thought the same, that and whelp if I screw up now it's worthless! :crazy: once that skin fit the way I hoped I finally took a breath.
  3. hillbilly75
    407
    Jan 7, 2011
    Nowheresville
    I started burning in the roof skin and I'm happy with the way it's turning out. I test fit the window trim to double check fitment and everything was a go. Not really a lot of pic worthy stuff but here are some anyway. I just have to finish both seams and the spot welds around the windows. I have a couple of days off coming up and hope to knock it out then.
  4. hillbilly75
    407
    Jan 7, 2011
    Nowheresville
    I have a little more build up on my welds than I like but I was afraid of burning through on the seams. Here are a couple more shots.
  5. 76_TypeLT
    6,392
    136
    Jul 26, 2008
    Houston, TX
    good job dude, those seams should clean up nicely
  6. hillbilly75
    407
    Jan 7, 2011
    Nowheresville
    Thanks Aaron, I think I spent more time playing with the settings on the welder than actual welding because of where on the roof this weld is located. I just want to have as little filler there as possible.
  7. 76_TypeLT
    6,392
    136
    Jul 26, 2008
    Houston, TX
    I hear that. Just take your time grinding down the welds, as that can warp the metal too. I am sure it will come out great.
  8. hillbilly75
    407
    Jan 7, 2011
    Nowheresville
    I got the seams & spot welds for the front windshield ground down. While I was at it I worked the pinch seam back into place above the window openings. I'm pretty pleased on how this is turning out so far. Next on the list are the spot welds for the rear window and making plates to weld in where the lead was.
    Driver side:
    Passenger side:
  9. hillbilly75
    407
    Jan 7, 2011
    Nowheresville
    I carved out some time over the last week and got the filler pieces welded in for the roof.
    I finished grinding the welds on one side, tomorrow hopefully I'l be able to do the other .
  10. hillbilly75
    407
    Jan 7, 2011
    Nowheresville
    I've been also working on removing the cowl that is in need of being replaced. I finished that up today. Looks like I've got some clean up and patch work to do in the corners.
