Here we go again...73 Z28
Discussion in 'Project Progress' started by brooksman9, May 3, 2014.
  1. clay's70
    clay's70 Moderator Staff Member Lifetime Gold Member
    2,116
    54
    May 3, 2008
    Chesterfield, VA (Richmond)
    Pat, you are the man!! It's coming along.
    brooksman9 likes this.
  2. Jas0n
    Jas0n Veteran Member Lifetime Gold Member
    1,012
    17
    Apr 27, 2010
    Verona, ITALY
    Nice!!
  3. brooksman9
    brooksman9 Veteran Member
    6,012
    128
    Jun 10, 2007
    Olive Branch, MS
    I hate doors (no pics). Today I removed the driver fender so I could adjust the gap on the driver door. Not bad, moved it forward a little and needed to adjust the striker. Got it a little too high and the damn door is stuck. Beat and kicked on it for an hour or more trying to get it opened. Still stuck. Going to slip a tow strap around it tomorrow and latch on with the cherry picker. Then I will remove all the hinge bolts so I can get the damn thing opened and start from scratch. :(
  4. McCune
    McCune Veteran Member
    942
    139
    Aug 22, 2015
    st.george utah
    I’ll bet you have worn out latches. Check them out closely when you get the door open.
  5. brooksman9
    6,012
    128
    Jun 10, 2007
    Olive Branch, MS
    Well it took me about five hours to get that damn door off. Still wound up prying it out and cutting the striker with a sawzall. Haven't looked at the latch yet. F'n door!
  6. clay's70
    2,116
    54
    May 3, 2008
    Damn it Man!!
  7. brooksman9
    6,012
    128
    Jun 10, 2007
    Olive Branch, MS
    Got the latch out. Sprayed it down with carb cleaner, wd-40, pb blaster and lithium grease. Working pretty good. Straightened up a few of the bent places from violent removal. Have it soaking in some old used motor oil for now. I will work on it some more tomorrow to see how well it will work. Then I'll decide if I want to replace it or not. Ill grab some pics of the door gap tomorrow too. Not as much as I wanted but as far forward as it will go. If I want any more I'll have to cut the quarter panel which I do not want to do. Gap is not quite a 1/4".
  8. brooksman9
    6,012
    128
    Jun 10, 2007
    Olive Branch, MS
    Gaps...pass side
    Driver side
  9. brooksman9
    6,012
    128
    Jun 10, 2007
    Olive Branch, MS
    Latch is working fine. I think the main problem was it was extended too far from the jamb and was hung on the striker. Installed the old one with one less washer. Door is as far forward as it will go.
  10. Double R Restorations
    2,704
    51
    Jan 11, 2002
    VA
    Glad you have it going your way now Pat. These doors are so heavy!
